2005 1000rr engine rattle
Discussion in 'General 1000RR Discussion' started by JA3llis, Jun 23, 2015.
  1. JA3llis
    JA3llis New Member
    Been for a quick ride this eve on my blade its got 11k on and full history. Iv noticed when cruising and revs are between 2 and 3k there is a slight engine rattle? Its the same hot and cold and dissappears when the revs increase. Does anyone have any ideas?
    Thanks
  2. martinowen
    Could be CCT on its way out maybe
  3. wilbert
    wilbert Active Member
    Mine does this too but is more of a "ticking" noise so I just make sure to keep it above 3000 rpm as it doesnt sound that serious. I can hear it more with ear plugs in too.
  4. Scott
    Scott Active Member
    I had a rattle and then It blew up
  5. JA3llis
    JA3llis New Member
    Thats it not a nasty rattle at all just strange i wondered if it was the injectors opening and closing that i could hear as if there anything like common rail injectors on cars there really loud
  6. wilbert
    I should add that it is not that noticable on mine and only when its not under any real load or on a closed throttle. Sounds sweet as at 11500 rpm, helped no doubt by the Akrapovic can.
  7. lambchops
    lambchops Elite Member
    Hmm will listen to mine today see if it does the same..
  8. -steves-
    -steves- Active Member
    Mine has a pinging sound if I try and accelerate at really low revs, goes away over about 3k from memory, just getting used to it now as I have been told its normal.
  9. Stumoores
    Stumoores New Member
    Mines exactly the same. Its normal
