Chain and spockets
Discussion in 'General 1000RR Discussion' started by bazzashadow, Jun 10, 2024.
  1. bazzashadow
    bazzashadow Elite Member
    As title I need new chain and sprockets
    But what would you choose???
  2. Boothman
  3. bazzashadow
    Same price as from a shop:D:D:D
    Just wondering what people use
    Honda
    Did
    RK
    Renthal
    Etc
  4. Broadie
    Broadie Active Member
    I use did xring and steel afam sprockets. In the past have found JT rear to be a little off center giving inconsistent chain tension.
    Also the thought of JT makes me cringe.
  5. Manofsteel
    Manofsteel Well-Known Member
    Rental rear and genuine Honda front.Tried Tsubaki chains not fussed on them so stick to DID now a bit lighter and seem better made plus no solid link to mess about with
  6. raphael
    Genuine Honda front sprocket, renthal rear with a did chain
  7. Sc_59_fireblade_sp
    Sc_59_fireblade_sp New Member
    RK x-ring chains come with a 20k mile guarantee.
  8. Selmer50mark
    Original Honda set on mine @24000 and still in good condition, the chain is Original too , Gold RK
  9. Sc_59_fireblade_sp
    I did some research on chains before ending up with RK. It seems that 20k is a lot to get out of any chain. Supposedly, top-shelf D.I.D. chains can last longer.
    My 'blade also came with a factory RK chain, which I presume to be O-ring. It was rusted and kinked by 17k miles. I'm betting the previous owner must have pressure washed the bike, which blew the seals out.
  10. bonjo
    honda OEM which is RK ~23k still in excellent condition minimum chain adjustment. The seals look like X ring
    In terms of sprockets, have a look at JT
  11. Selmer50mark
  12. Broadie
    4 you sure about that?
  13. bazzashadow
    Definitely RK mark
    And I have just noticed RK on the Honda BSB leathers
  14. raphael
    just because it’s on the leathers doesn’t mean that’s what’s on the bike! I can assure you there’s no resemblance between the stock and what they use as I get my chains off those race bikes.
  15. bazzashadow
    Agree
    Ford is on there as well
    :D
  16. bazzashadow
    Back to this again:rolleyes:
    I haven’t brought them yet but I was just checking mine and it is 15 front sprocket and 43 rear
    Now the book says 16 front and 42 rear
    What difference would this make if any???
  17. bonjo
    Engine rpm it higher for smaller front sprocket and going bigger on the rear sprocket is maybe to keep the speedometer calibration.
    You can find it n line tools to find out the overall gearing difference between 15+43 and 16+42
  18. raphael
    RPM is only 500 rpm more and very slightly more acceleration, nothing major to be honest
  19. bazzashadow
    Line tools????????:confused:
  20. Nigel H
    Nigel H Active Member
    If it's anything other than stock it messes the speedometer a bit.
    Mine came with a smaller front trading top speed down for more torque to the wheel (like I don't need 200mph all that often).
    I got tired with doing the offsets in my head and put a Healtech box on it.
