Power commander for an RR6
Discussion in 'Wanted' started by Andrew, Aug 25, 2011.
  1. Andrew
    Andrew Active Member
    As above really i'm looking out for either a PCV or a PC3 USB that will work on my 06 CBR1000RR so if you've got one for sale or you've spotted one going at a good price could you give me a shout please!!
    Andrew
  2. dan.1moore1
    If i see one i will mate
  3. flatstickHRC
    flatstickHRC Active Member
    There loads on eBay. It's a really common one as it fits lots of bikes. You can get a used one for £150
  4. Andrew
    I've just been for a nose on the power commander website and the power commander 3 USB for my bike is: 125-411 now I couldn't see any other honda models with the same PC3 part number but load had same 3 final numbers -411. So do you mean all the models with the final 3 numbers of the PC3 model ending in ___-411 should be okay to use???
    Cheers Andrew
  5. dan.1moore1
    Probably best to give them a ring mate
  6. rocket
    rocket Active Member
    every power commander i,ve had ends in 411 its the first 3 numbers that are bike fitment numbers. i just sold my pc3 for the 06-07 blade which was 125-411 but the 04-05 one that is 121-411 fits and works just needs the 125 maps loaded. hope this helps.
  7. flatstickHRC
    Like the cb1000 one fits the blade but you just change the maps. And the instructions don't match too.
  8. JM1
    JM1 Active Member
    Don't forget to get an O2 sensor eliminator too.
  9. Andrew
    Mine doesn't have an O2 sensor because it a USA spec bike, which if find really odd!
  10. JM1
    JM1 Active Member
    Ah OK sorry didn't realise it was a US bike.
  11. viper_biker
    viper_biker Active Member
    If you want to fit a PCV the one for the 600rr fits and you just load the correct map. Have a look on the 1000rr.net site for which model of 600 it is.
  12. twistingthrottlenz
    twistingthrottlenz New Member
    I purchased a PCV for the 06 1Krr which came with correct connectors. As for the O2 eliminator I simply added a 300ohm resistor to bridge the white and black/white wires in the harness end of the O2 sensor plug.
    You can find the plug inside your right fairing by the frame - theres a bank of 4 plugs and its the first white plug from the left (from memory I think the order from left goes red, blue, white, white) with the third plug being O2 sensor. I only had to take off a few bolts and my frame slider to bend the fairing back enough to give me access.
    Just unplug, fit a resistor (theres convenient little holes in the metal part of the plugs where the stalks from the resistor can clip in), tape up, and no more Fi light
  13. JM1
    JM1 Active Member
    I thnk he might have managed to get it done in the year since this was posted :):):)
  14. twistingthrottlenz
    haha yeah i know mega thread revive, but when i did my searching i came across heaps of dead end threads with no answer which didnt help me (or anyone else) at all.
    now this one has an answer :)
  15. Andrew
    Cheers!! lol
