Hi, Ive just fitted the LV end can onto my bike connecting o2 sensor and removing baffle. Sounds fab and runs great, however a few times ive noticed the idle revs being a little erratic (not all the time) Is this due to baffle being removed? or the something with the o2 sensor perhaps? Is this normal ? The can is supposed to be fine on stock fuel settings. Any thoughts ?? Thank you
Ill put a pic on shortly. Looks nice and don't even think ill get the carbon fill in piece. Looks good without it and saves £80.
I think I have exactly the same can on my 08, but with PCV and O2 sensor eliminator and I don't notice any issue with idle revs. Suggesting it's a fuel mapping characteristic. Depends what you mean by erratic. The ECU controls the idle speed, maybe it's just settling down to a steady idle or something. I agree with stevebetts though and suspect that baffle in may improve matters - depends how bothered you are and how bad the problem is.
Thanks for the reply. Ill try with baffle in. To be honest it's not a big issue, and it's not a constant issue. By erratic I mean at idle the needle will flick up and down more so than usual. It rides fine. I don't really want to have to fiddle around with a PC or sensor eliminator it shouldn't need that messing with. Cheers
