Small crack on the front fairing (windsreen screwhole) fix?
Discussion in 'Maintenance' started by bazz, Nov 10, 2012.
  1. bazz
    bazz New Member
    EDIT: Sorry the text dissapeared...
    I managed to get a crack on the front fairing when i was chainging windscreen today.
    Its about 4cm and hardly visable. It cracked by the screwhole.
    Is there any simple fix you can recommend that dosnt require taking the fairing off or repaint afterwards?
    I just dont want it to get worse when i take it out for a spin... =/
    Feel stupid.. but it was a misstake bah =/
    #1 bazz, Nov 10, 2012
  2. Alblade
    Alblade God Like
    Nightmare - my guess is no, but perhaps a washer and some car body repair material - perhaps take good photo of both sides and send to a fairing repair place and see what they can do?
  3. martinowen
    It's one of those things that most probably no one will notice
    But you know it's there! :mad:
  4. bazz
    bazz New Member
    Yeah, Im just scared it will become worse cos of wind and vibrations.
  5. dave d
    dave d Elite Member
    your not the first Bazz brittle as owt mate.. [​IMG]
  6. martinowen
    I think they tend to repair a crack in plastics and fibreglass by firstly drilling a hole at the start and end of the crack as this stops it being able to continue any further. As for the rest of the repair I don't know how much it would cost it maybe cheaper just to order a new nose
  7. phantom
    phantom Active Member
    Welcome to the cracked nose cone club
    These blades have the poorest quality
    Plastic of all the modern bikes imo.
    It you can use good glue to hold it
    That's what I have done with mine .
  8. kpone
    That's why women have belly buttons.
  9. gRRandeelion
    gRRandeelion Active Member
    I dropped my RRN years ago and managed to put two small cracks in the fairing, I drilled a small hole at the ends of the cracks and 20,000 miles later when I sold it the cracks had not spread.
  10. 1000rr73
    1000rr73 Active Member
    Yep, I didnt spot the crack on my rr8 nose cone until I got it home. Really pissed me off as I went over the bike in such detail too.....anyway I tried to repair with superglue and whilst not perfect it held fine for another 10k miles. My advice though would be just live with it as you'll never really hide it well, particularly in black, and will always look worse than that hairline crack.
    Front fairings come up on eBay for around £100. Keep your eyes peeled, but if it really bothers you they're like £200 RRP.
  11. bazz
    bazz New Member
    Ok, but i dont think i want to drill a hole there =(
    Ill just live with it and get a new one if it becomes worse (i expect it will)
    What kind of glue should i use on the inside? Any ideas?
  12. ColinBR
    I picked up a front nose cone for £90 on the evil bay mate. So it shouldn't be too expensive a repair if you do want to replace.
    As for glue I'd use a 'little' superglue on a fine tipped paint brush (like the ones used for painting model kits) and add layers to the rear of the crack.
  13. dave d
    dave d Elite Member
    #13 dave d, Nov 10, 2012
  14. martinowen
    If you do replace for new make sure you PM Cox Honda and MrB, both on here as they come up with some really good prices!
  15. phantom
    I used gel on mine gluing from the back.
    unless you look closely you wouldnt spot it.
    im not changing it until I buy a new end can first :D
  16. bazz
    bazz New Member
    Thanx everyone!
    Feel alot better already =)
    What kind of gel did you use Phantom?
  17. martinowen
    Bazz check out eBay item - 271101350319 it's only 40 quid
  18. martinowen
    Ignore that mate I just read the rest, it's scuffed on the side
  19. Jollygiant
    Jollygiant Member
  20. phantom
