hel lines
Discussion in 'Mods, Upgrades, Accessories and Products' started by gringo, Nov 17, 2012.
  1. gringo
    gringo Active Member
    going to get some hel brake lines from guy on this site do i go for line that are same as on bike the cross over front mudguard and do they fit the same
  2. fez.57
    fez.57 Well-Known Member
    i went for 2 lines running direct from the master cylinder and they fitted using the existing connections, i dont think there is any real performance differance between the 2 set ups
  3. ddc
    ddc Member
    Yep same for me and i got them from wezmoto who were cheaper and use hel lines anyway ;)
  4. hrc oz
    hrc oz Member
    i find the two lines are easier to bleed than the original lines :)
  5. Jollygiant
    Jollygiant Member
    I like the 2 line setup, just prefer how it looks to be honest.
  6. ams
    ams Active Member
    Hey mate thanks for the info.
    I too am about to buy a set off here... can I confirm that it's a direct 'bolt on' and everything is provided in the HEL kits ?
    Thank you
  7. gringo
    thats what they say line banjos washer the lot just pick 2 lines or original set up and the colour think il go for same set up as original
  8. JonnyAnnett
    JonnyAnnett Active Member
    It really is personal perference on the layouts of either over mudguard or two full length lines for general road use. Although 95% of our kits would be the full length options as thats what most people tend to what.
    As I say for the general user you aren't going to notice much of a different in the two layout configurations, although the two full length lines effectively is a better layout as it provides a more equal brake pressure to each caliper.
    All of our kits (HEL) come supplied with everything you need to fit them. I.E. Stainless steel banjo bolts, copper washers etc. All you need is a bottle of brake fluid and away you go!
    See our thread here for the forum deal, which I'm sure you will agree is a fantastic deal http://1000rr.co.uk/bikebitsni/3983.htm
    Thanks
