1000RR 08: Battery problems..
Discussion in 'General 1000RR Discussion' started by bazz, Jan 3, 2013.
  1. bazz
    bazz New Member
    Hi guys
    I dont know whats wrong, wondering if someone of you have more knowledge about batteries..
    My bikes is acting wierd. Tried to charge it fully. Then its starts.. think it had like 13.20V when its fully charged.
    A few days later its down to 12.75V. When i try to start it it wont start and after one try the battery is down to 12.33V.
    I dont have stuff that can drain the battery.
    Is it time for a new battery or does it sound like something else is wrong here?
  2. Shameless
    Shameless Active Member
    Sorry to say but I think its time for a new battery, They can show 12 volts but don't have the amps to turn the bike over.
  3. Jamiestrada
    ^^ agreed the ducati was doing the same to me batt change and all is sorted :)
  4. bazz
    bazz New Member
    Ok damn.. =)
    Any recomendations on batteries? I got a few things that will drain and eat power later on. Scorpio i900, Xenon, Iphone charger.
  5. Remal
    SES lithium one I just got does not loose charge as much as a regular battery and is much much lighter but cost me £100
    other than than just use the recommended battery that is already used on the blade
  6. Jamiestrada
    OE are good or as remal says lithium light but pricey :)
  7. Shameless
    send a pm to our friends at demon tweeks, in sure they will sort you out a good deal.
  8. Gregr
    Gregr Active Member
    Just make sure you get a good quality battery, you could go for standard fitment Yuasa battery; I got a Lucas battery at a good price and seems very good so far. I posted my story elsewhere on here if you can find it "Tale of two batteries" I think I titled it. Main thing is you need a battery with at least 130 Cold Cranking Amps, known as CCA in the trade as I found out. The Lucas on is 150 CCA, Standard Yuasa is 130 CCA. I'm sure you may find others out there but avoid Poweroad batteries they only have 80 CCA, I had one fitted by my Honda Dealer and it caused no end of aggro.
  9. scooby
    scooby Elite Member
    it's the cold weather that will kill your battery,get yourself an optimate to keep it conditioned whilst your not riding it,if your using it regular then it should be fine.
  10. bazz
    bazz New Member
    Its standing in a very warm and cosy garage, being maintained every week.
    Ill try and find a good battery for the bike.. not being able to trust that it starts is one of the worst feelings =)
