What do ya all use to Clean your bikes
Discussion in 'Maintenance' started by samuk, May 8, 2013.
  1. samuk
    samuk Well-Known Member
    As the title says...
    looking for something..but unsure what to get...
    Thanks
  2. Slick
    Awesome stuff
  3. fez.57
    fez.57 Well-Known Member
    After my first try today with the meguires ultimate range i can honestly say i have never used such quality products
  4. Si.
    Told ya.
  5. Slick
    +1 with the Meguires range, the finish is amazing.
    but what do you used to get the muck off in the first place?
    For wheels and similar areas I like to use vulcanet wipes, grease and muck just falls off. Just to add I always wet wash the bike before using the wipes!
  6. Brym
    Brym Active Member
    SDOC100 another vote top stuff
    Castrol greentec nearly as good as SDOC and a bit cheaper
    or
    my latest find that I use on all my bikes, mountain bike MX and road etc
    Non Caustic Metal Cleaner | Rhino Goo
  7. fez.57
    Personally i dont use anything apart from a clean rag and just take my time doing little bits at a time. Dip the rag in water to help remove flies ect and thats it. im sure specific products would work better but im happy with my method and it works
  8. blade1980
    blade1980 Active Member
    Mr.sheen, does a great job of removing flies and using spring fresh gives the garage a lovely smell too!
  9. RichC
    RichC Active Member
    Pre-rinse
    MUC Off bike cleaner
    Rinse
    Wash with Meguairs gold class shampoo
    Rinse
    Drying towel
    Baby wipes on wheels
    Meguairs quick detailer with a soft polish cloth
    Run upto temperature on paddock stands to dry chain
    Place on side stand so any excess trapped water can fall out of lower fairing
  10. Salemsport
    Salemsport New Member
    Most of the MUC OFF range and Meguiars! Quality stuff!
  11. arthurbikemad
    Something like:-
    Rinse HOT
    Snow foam
    Rinse HOT
    Ph wash (Carnauba wax PH neutral wash)
    Rinse HOT
    Air line
    Pre wax cleaner (non abrasive)
    Zymol or Supernatral or maybe Raceglaze 55 (best smelling wax ever) Two coats.
    Synthetic Sealant
    Use micro fibre cloths grit guard buckets etc etc
    I love cleaning.. Even my customers bikes get the full monty from time to time if I have time to do them.
  12. Pete H
    Pete H Active Member
    Well I always go here ; ;)
  13. Kentblade
    Muc Off degreaser spray on rear wheel, swing arm etc,
    Muc Off or snow foam,
    Megs hyperwash,
    for a wax Collinite 845 or Zaino Z3 evry 3 months
    Top up after washing Z6 or Z8
  14. MOz
    MOz New Member
    Another snow foam convert here.
    Just wish I had access to an airline for a complete contact-less wash....
  15. billo01
    billo01 Member
    Damp kitchen towel left on the fairings to soften the bugs that have gone hard then good old mr sheen, even use sheen for cleaning chain lube that's been flung off. Soft bottle brush to get the bugs off the radiator.
  16. billo01
    billo01 Member
    Damp kitchen towel left on the fairings to soften the bugs that have gone hard then good old mr sheen, even use sheen for cleaning chain lube that's been flung off. Soft bottle brush to get the bugs off the radiator. Sometimes use autoglym polish too.
  17. arthurbikemad
    Asda do spray polish for 17p! :)
  18. phantom
    phantom Active Member
    power hose,
    Muc-off spray and
    Muc-off degreaser on the chain
    Power hose,
    Leather cloth dry
    Maguires nxt wax
    One last go over with good finishing
    Cloth to really bring the shine out.
    Wd40 all black plastics then wax
    The chain.
  19. julestys
    julestys Active Member
    Muc Off takes some beating
  20. Remal
    I have laods of cleaning gear from what has been suggested. Been trying out the Sdoc100 gear and it's really good.
    Microfiber clothes, and or wool mitts for washings. snow foam works well to remove crap from a bike but i don't do it much as the bike never gets really dirty
    Finish Kare detaling spray is very good at removing light crap or just to clean the bike after a wash. Loving DODO juice stuff from their wax, sealants etc...
    A top tip for one of the best sealants out there which is very reasonably and last for years is FinishKare 1000P Hi-Temp Sealant
    Finish Kare 1000P Hi-Temp Sealant - Clean Your Car
    best sealant I have used and I've tried allot
    I get much of my stuff from
    Car Care Products | Detailing Products | UK - Clean Your Car
    always good service
