GoPro mount
Discussion in 'Mods, Upgrades, Accessories and Products' started by Fletch, May 11, 2013.
  1. Fletch
    Fletch Active Member
    Do any of you guys have a GoPro
    Mine should arrive next week
    How do you mount it to the blade?
    I've got a Telferizer mount, and am about to buy the GoPro Ram mount
    I've been told it can still have quite bad vibration ...
    What other mount points can i use and how can i mount it?
  2. Si.
    I mount mine on my helmet.
    ooo err missus.
  3. Jollygiant
    Jollygiant Member
    Just the flat sticky pad, one front one rear for me
  4. Slick
    Flat spot on the tank gives a nice view of the cock pit, - I've been advised its not a good idea to show the speedo unless on the track!, or the flat spot on the nose cone. Borrowed one on a Track once, the suction mounts were solid at 150+
  5. robinh73
    robinh73 Well-Known Member
    I have also used the suction one and it is solid both on track and road, so no worries there.
  6. Fletch
    Is that the RAM suction mounts or do GoPro have there own??
  7. gazjekyll
    gazjekyll New Member
    I have the black edition and found the sucker mount sticks down well but does vibrate quite a bit when on the tank. Like some of the other people on here I used the flat sticky mount on the rear and the curved on the front nose I've ordered the side mount to use on either side of the fairings the filming quality is pretty good.
  8. Fletch
    I've got the suction cup... It arrived today
    I've also got the ram mount on order... So I will report back on which he is better
  9. Alblade
    Alblade God Like
    Bolt to ventura rail for rear facing super solid footage, front = curved sticky mount between headlamps where nose cone most solid = most stable footage - any movement is magnified a huge amount = horrid footage to watch back
