  1. Slider
    Slider New Member
    Hi Viper_Biker, what plastic weld did you use? I bought some from motorfactors and it was shit.
    Slider
  2. Muffking
    New roll of carbon wrap arrived today, so I took to removing the infills & exhaust cover that I wrapped before as I didn't like the finish.
    Upper tank infill before, along side my spare infill that I used to test if the new carbon film was any good.
    How the other infill & heat shield cover looked with the old film.
    With the new film.
    Parts fitted back on the bike.
    May re-doo the chain guards tomorrow, as this film stretches quite well.
  3. Muffking
    Set to with wrapping the chain guards today and had a time consuming go at the old rear hugger too, turned out quite well. While there, removed the lower swing arm stickers and cleaned it up as they were unsightly.
    Gonna sell the old carbon rear hugger now as it wasn't quite as good a fit as the original.
  4. F1reblade
    F1reblade Active Member
    Took off the pillion pegs to find my rear res bolt quite corroded. Got an allen head bolt from my old VFR and cut it down to size. All is now shiny again :)
  5. 3056tat
    3056tat Active Member
    Put baffle in can and reflector on number plate to take bike for mot.
    Bike passed, rode home and removed them for another year.
  6. simong81
    simong81 New Member
    Increased the bhp and torque massively with a Bazza fueling unit, replaced the air filter with a K & N unit, had the suspension set up and it spent time on the Dyno to ensure it is all running as I'd like it!
  7. paulbusdriver
    paulbusdriver Active Member
    Took my 2013 blade to Crescent Suzuki Verwood, to get it remapped for R77 end can, bmc filter and PCV. Not allowed to watch the abuse in the inner sanctum , but you could here it from their first floor viewing area over the workshop. After 2 1/2 hours he had re mapped my bike with the baffle still in , as I do use on road .had a ferry to catch to get home , otherwise would have done a 2nd map, the bike now pulls cleanly with no bogging down around 3000rpm and now produces some 5hp more up to 8000 then climbs to an extra 20 hp . Base map was 145(this is the power commander base download map that the dealer had loaded when they supplied new bike n bits etc!!) final map is 166hp with more torque and a flatter fuel air line. Very impressed with the customer service here.
    Happy chap.:)
  8. si1000repsol
    I got my Marchesini Genesi M7 wheels
    • Like Like x 10
  9. martinowen
  10. dave d
    dave d Elite Member
    Very nice Si
  11. fez.57
    fez.57 Well-Known Member
    I need to see some pics of these fitted to the bike asap as they look stunning
  12. el-nicko
    el-nicko Well-Known Member
    Yor Guinness has gone flat! :D
  13. SimonRR
    SimonRR God Like
    Just test fitted the track fairing I bought off PeterC, after a deep clean, some filler, touch up paint, ebay decals, and stomp grips, looks reasonable?, and it will take a weight of my mind when on track ;):D
    #2273 SimonRR, Jun 15, 2013
  14. Muffking
    Meet my almost twin :D
    That looks really good.
    As for me, I fitted a set of Gilles rearsets I got from Barstewardsquad.
  15. F1reblade
    I completely dismantled (ok maybe not completely) my bike ready for the tail light and indicators to be fitted on arrival. Someone please tell me why Honda put the relay inbetween the headlights. Can't wait to try and put this lot back together again. ImageUploadedByTapatalk1371323863.937851.jpg
  16. martinowen
    I extended my relay with 2wires too behind the left hand panel for ease if it ever blows etc, while its apart you may aswell do it
    Also you may find it easier to refit the nose if you remove the screen as it gives you a bi more flexibility
  17. si1000repsol
    Here's a photo of them fitted with
    Michelin Power Pure for maximum
    Weight reduction
    • Like Like x 6
  18. martinowen
    Si let's see some full pics of the bike mate, you must of poured some serious ££££ into that lately but she's looking f ing fine!
  19. F1reblade
    Thanks Martin.
  20. SimonRR
    SimonRR God Like
    Thanks Martin but Not spent that much mate :D
    The track fairing was cheap enough due to being tatty, and the stickers where off Ebay and under £20 (lets hope they don't peel off lol :eek: round the track)
    Apart from:
    Harris folding levers
    Braided hoses
    scorpion exhaust
    DID gold chain
    Talon +2 rear sprocket std front
    Stomp grips
    gear indicator
    Speedo healer
    K&N Air Filters
    crash bobbins to frame and forks
    Tail tidy when her Sunday best is on :D
    she is bog standard :eek:
    Need a Power Commander next
