Brembo master cylinder query?
Discussion in 'Mods, Upgrades, Accessories and Products' started by blade1980, Jun 28, 2013.
  1. blade1980
    blade1980 Active Member
    Looking to up my stopping power with one of these, hel lines and poss new pads, which one do I want, is it 19mm and what's the difference between 18 and 20, just adjustment?? Do I need different reservoir too??
  2. Slick
    It's the 19rcs 18-20 you want. The 18-20 refers to the adjustability of the lever which controls the travel and progressiveness of the
    force emitted to the pistons
  3. blade1980
  4. si1000repsol
    Just bought the RCS 19 as it offers both the 18 or 20 options.
  5. si1000repsol
  6. blade1980
    Cheapest found on the bay is £238, this works out around £220
  7. blade1980
    Did you get a new resovoir too, seen reports you need to change it as well
  8. si1000repsol
  9. si1000repsol
    I haven't got one yet but will be.
  10. MOz
    MOz New Member
    Just be wary of fake ones floating around....
  11. Scott
    Scott Active Member
    No way fake ones
  12. si1000repsol
    Well mine looks pretty real from what I can see
  13. stevebetts
    stevebetts Well-Known Member
    You can use the standard reservoir (I did).
    You have to make a different bracket to mount it though.
  14. stevebetts
    Here's a section of the thread when I did mine....
    I wasn't happy with the bracket i made to hold the stock reservoir to the new RCS.
    Today I decided to do a mark 2.
    I basically copied the stock res bracket but added a mounting hole at 90 degrees to the original position to suit the RCS clamp.
    I am really happy with the result.
    The bracket took some bending to get it just right, but i think it looks great now.
    Comments please.....
