CBR1000RR 2010 bi-xenon projectors
Discussion in 'Mods, Upgrades, Accessories and Products' started by tgosai, Dec 3, 2012.
  1. el-nicko
    el-nicko Well-Known Member
    Cheers mate, thanks for that. Just one point:- I notice in pic's in that ebay ad' that the dip cut-off is for a left-hand drive vehicle (see attach) so I'm asking; Do you think it's possible to switch the solenoid operated dip 'paddle' ( the pink coloured thing at the bottom right of the attached pic') around before fitting ? It certainly looks like it 'cos there are two redundant holes in the top of it.
    #61 el-nicko, Mar 23, 2013
  2. phantom
    phantom Active Member
    on another note my car was going to fail mot for led strips below the
    headlight.so after pleading with the tester I ripped them off it front
    of him to get my pass cert.....need new strips now :s
  3. hump333
    hump333 Member
    No no, in projector lamp it has the same in both sides ie both lights will be on at same time on lowe beam an when you put hi beam on again both projector will come on they have own solenoid in each lamp.
    It doesn't matter if its left hand drive or right tbh. The item I sent you on ebay is the cheapest around. Plus the fit in 2004 2013 blades :D
    #63 hump333, Mar 23, 2013
  4. johncbr
    johncbr Active Member
    has any one done this yet ?
  5. hump333
    hump333 Member
    Done what?
  6. Muffking
    Dunno, but i ran both 35W HID's at the same and flattened my battery after a ride, so have gone back to Bi-HID's if that helps?
  7. hump333
    hump333 Member
    I lift my ignition on other day and both angel eyes n projectors was on for well over an hour, till I realised an my bike started find. My light have been on my bike for "7 month's" now with no problems at all. Even had voltage meter on battery, no power lost/or dran.
    Mine are 35w hid G5 bi xenon projector's. Fitted these to few 2005 to 12 blade n gexr with no issues:) and Sold about 9 complete units with no problems:)
    #67 hump333, Jun 30, 2013
  8. hump333
    hump333 Member
    I left my ignition on other day and both angel eyes n projectors was on for well over an hour, till I realised an my bike started find. My light have been on my bike for "7 month's" now with no problems at all. Even had voltage meter on battery, no power lost/or dran.
    Mine are 35w hid G5 bi xenon projector's. Fitted these to few 2005 to 12 blade n gexr with no issues:) and Sold about 7 complete units with all happy bikers. [​IMG][​IMG]
    #68 hump333, Jun 30, 2013
  9. johncbr
    i wanted to know who put these projector's on there bikes ? any problems ? do they kill the batt ? ( as usein a race batt ) and where in england do you get them in kit form or as a unit ?
  10. martinowen
    Hump Can you do them like the sick hid ones mate? I like the one that you can just run the angel eyes, or angel eyes and red centre or you the centre can just go white on full beem
  11. hump333
    hump333 Member
    Martin its only colour temp. Or some kits come with a meter that you can reduce power to the bulbs. (Ie like dimming ) But these can't be bi ~ xenon bulbs as these bulbs only run off 23000v from the ballast.
    Them lights are off 2008/ 12 blade
    #71 hump333, Jun 30, 2013
  12. hump333
    hump333 Member
    Projector Kits on ebay light units too.
  13. hump333
    hump333 Member
    #73 hump333, Jul 2, 2013
  14. martinowen
    Yea they seem to be able to change colours and flash and strobe, I presume some kind of control panel. They do all makes and models but for a lot more than you charge! Just seeing if you are able to do similar
  15. hump333
    hump333 Member
    If you find the make of them I'd able to fix them up. They must be £££ and weight alot more than the standard type.
  16. hump333
    hump333 Member
    :D
    #76 hump333, Jul 3, 2013
  17. watkins58
    watkins58 Active Member
  18. jnc102
    jnc102 New Member
    These look awesome - def going to have a crack at doing this to mine over winter! Well done mate
  19. hump333
    hump333 Member
    I have set made up for 2004/2007
  20. Pete1987
    Pete1987 Active Member
    When is your expected delivery for these?? They look awesome and I was thinking of doing it myself but a replacement set of headlights would be better in my eyes.
    Pete
