Pair of Wheels for an 08+
Discussion in 'Parts, Accessories & Clothing' started by Barry_m2, Oct 4, 2013.
  1. Barry_m2
    Barry_m2 Active Member
    I have a pair of wheel to fit an 08+ Blade. They are 04-07 wheels, the front has been modified to fit an 08+ and the rear drops straight in to the 08 swingarm with the 08+ sprocket carrier which is supplied with the wheel.
    They are black, in pretty good condition, good to use as a spare trackday or race set for wets!
    £200
    No tyres fitted, no front disks but rear has a disk and sprocket carrier.
    Can post, you can collect, or I'll be at Brands Hatch this weekend too if you want to collect from there.
  2. Scott
    Scott Active Member
    Just one question mate. What's the disc pattern on the front. 08 or 07 , thanks
  3. Barry_m2
    Disk pattern?
    It's the same from 04 all the way through mate, they are all same fitment.
  4. Scott
    Scott Active Member
    Oh right sweet. And how did u modify front plz
  5. wedgiewolves#223
    wedgiewolves#223 God Like
    You sure buddy ? 04-05 had 300 mm discs 06-07 have 320mm discs and 08 discs have a narrower profile from centre Hub outwards . I could be wrong
  6. Barry_m2
    Oh, diameter wise yes, 310-320 on the later.
    Disk fitment is the same. I had 08+ Discs on the modified 07 wheel. That's the wheel that's different though, not the disc. ;)
  7. Barry_m2
    The wheel had 5mm machined off the wheel where the disk mounts, just taken a pic so you can see....
  8. martinowen
    Would these still fit an 05?
  9. wedgiewolves#223
    Good to know thanks
  10. Barry_m2
    The rear will (I have two rears) but the front won't.
  11. 999bub
    999bub New Member
    Hi, are these still for sale. I have a standard 08 blade and want a set of spare wheels. If I buy these do I just need a sprocket, and some 08 front discs and it should all work with my bike? If so il take them and would need posted to Somerset.
  12. Scott
    Scott Active Member
    I bought them sorry
  13. 999bub
    999bub New Member
    Is there one rear for sale still then?
  14. Barry_m2
    All gone I'm afriad.
  15. Barry_m2
    Scott, how did you get on with the disks, did they work with the stock calipers, are you wanting to keep them?
    I've got the disk bolts too I forgot to give you, so if you PM me your address I'll post them on.
