1st gear clunk
Discussion in 'General 1000RR Discussion' started by Dec, Dec 5, 2013.
  1. Dec
    Dec Active Member
    Gear shifts are fine, but going into first from stationary give's a real #CLUNK@
    Could it be my 09 Blade or is this typical.
    Anyone know a fix? Should I use higher viscosity oil?
  2. Stimo
    Stimo Member
    same on my 06 blade mate but wouldnt mind knowing why
  3. Mattlong
    Mattlong New Member
    Check your chain, clunky gear shifts and false neutrals are often down to slack chain.
  4. kev.b
    kev.b Well-Known Member
    Make sure chain is adjusted . Holding in clutch for a few seconds before selecting gear works .
  5. martinowen
    It's a Honda thing
  6. Si.
    Normal mate.
  7. Jkaye
    Jkaye Active Member
    My 09 is the same, normal :D
  8. raphael
    had that on every honda i have had
  9. ShinySideUp
    ShinySideUp Elite Member
    Tbh I have found most bikes do a bit of the clunk thing going into first but best way to minimise it is to wait a few seconds after pulling in the clutch lever before actually switching into first gear.
    But as said double check your chains not too slack as this can make it sound worse if not correctly adjusted.
  10. mr.h
    mr.h Active Member
    Normal for a Blade my 2007,2010,2012,2013's all do it/did it see a pattern emerging! my Speed triple doesn't clunk but its a different gearbox. Be careful with the chain tension - too tight will defiantly cause some damage. stick to the recommended tension
  11. The.kickboxer
    The.kickboxer Active Member
    As soon as I saw the heading I knew I was gonna find a lot of that's normal. I nearly didn't buy a 2005 blade coz of it. Now on my third (2011) and I don't even notice it anymore.
  12. rocket
    rocket Active Member
    don,t think ive ever had a bike that hasnt done it!
  13. Dec
    Dec Active Member
    Thanks guys, will double check the chain tension.
    I know its typical for a bike, but seemed very harsh on my Blade and knew it couldn't be wear and tear as its only done 3.7K
    Reassuring to know ;)
  14. flynn07
    flynn07 New Member
    I find if you clutch in and give it a bit before engaging it seems to drop in a bit smoother
    Possibly a safety feature ,you wouldnt want it to drop in when stood tickin over and your 5 yr old gives it a little blip:p
    My ninja done the same too
  15. Clarkey
    Clarkey Member
    Yes matey normal all my bikes I've owned make a clunk into first gear so nothing to worry about
  16. sinewave
    I think a lot of the reason why Bikes have this 'Big Clunk' when engaging 1st is that when a bike is idling in neutral there is a big diff in the rotational speed of the engines clutch plates and the stationary gearbox cogs, thus when 1st is engaged this 'differential' is 'equalised' thus causing the Clunk.
    Once the box is on the move this differentiation is almost nil hence why shifts seem so slick on the move.
    This is also what happens when you miss a full bore up change and then have a second attempt at engaging the next gear and you subsequently get another big clunk at the engine speed has now overtaken the gearbox rotational speed.
  17. Toy40
    Toy40 Active Member
    Lets the que of traffic around you Know your on a 1000cc not a 125!!!! BANG!!!!!
  18. phantom
    phantom Active Member
    honda thing,older models were louder
