difference between 2011 & 2013 blade
Discussion in 'General 1000RR Discussion' started by Skippy79, Oct 8, 2013.
  1. Skippy79
    Skippy79 Active Member
    whats the big difference bewteen the 2 types of blades?
    any engine, BHP, torque differences?
    Might be able to pick up a 2013 blade for the track and wanted to see what the difference is?
    do the older type blades wheels fit in the 2013 ones? seems 2012/13 wheels are as hard to find as hens teeth :D
    and what things would be straight bolt over??? rearsets? clip-ons, exhaust systems......
  2. SIDEWAYS
    SIDEWAYS Senior Member
    Everything is the same apart from bodywork, headlights and front wiring.BHP difference is minimal just smoother pick up on the 13 blade.Personally I do like the 13 bodywork but would not spend 3-4k on changing my bike for one though.
  3. Skippy79
    so I'd be paying extra for the nicer wheels and the nicer clocks, for the rest everything is basically the same?
    but I'd be getting a newer bike with less km than the older one
    cheers
  4. Buckmeister
    Buckmeister Active Member
    Suspension is different too, it's better but not £4k better !
    There are still a few low mileage 08-11 plate bikes around if you look on Ebay / Biketrader.
    I want a newer model in the spring but I'm only buying one as the mileage on my current bike is getting quite high, otherwise I wouldn't bother as the
    differences are minor. More second hand bits around for the older bikes too, that might help you out in the long run if you're at the track a lot !
  5. PeterT
    PeterT Active Member
    New ones are faster....................... especially in red.
    That's what I was told.:D
  6. stuart_g
    stuart_g Active Member
    2012 and 2013 blades are exactly the same it is only a colour change.
    2011 and 2012 blades are different as follows.
    Wheels are different design
    Bodywork is different shape
    Headlights, different shape to fit bodywork
    Front forks are Showa big piston type
    Rear shock is a Showa unit and different to 2011
    Dash is fully electronic and there is no needle type (analogue) rev counter.
    I also believe the ECU is different and has a different fuelling map.
    I think that is it and I haven't missed anything.
    Having owned a 2010 and now a 2012 the difference in suspension is like night and day, 2012 is far better.
  7. sinewave
    If you are buying for Track use the MY12-13 Dash has a built in Lap Timer display.
    You can also switch to Kilometers per hour if traveling abroad etc
    If buying for Track use then search out a MY12 model as the MY13 is just a diff paint job but will cost ya more
    #7 sinewave, Oct 8, 2013
  8. Skippy79
    ok thanks....
    any chance wheels are inter changable 2008-11 and 12/13??
  9. sinewave
    Dunno TBH, you could try asking your local dealer or indeed Honda UK themselves?
  10. dave d
    dave d Elite Member
    Marks got some 2012 wheels
    spares
  11. Ian E
    Ian E Active Member
    Yes wheels are a straight swap. Note that the ABS rear wheel is different to a non ABS rear wheel.
  12. Skippy79
    would want to take the ABS off, so hopefully that won't be a problem ;)
  13. sinewave
    If you don't want ABS then don't buy a Bike with it fitted.
    It's not a simple case of just switching it off, in fact you can't bypass it unless you start pulling fuses etc and then it only stops the various modulators working of which there are at least 4.
    The Bike will never feel or stop as well as a Non-ABS Bike with the system bypassed.
  14. Skippy79
    cheers
  15. yorkshiregooner
    yorkshiregooner Active Member
    Get my 13 plate bought n stop messing about Alex:)
  16. Skippy79
    hahhahaha, not an abs bike though, right ;)
  17. Fletch
    Fletch Active Member
    So I ordered last week and my fairing kit has arrived!
    Its the IOM TT Colours!
    It looks good, the plastics look well made, the paint on the good side looks superb! Only had a few bits out the box but will give a report as i go! (will be after Christmas!!)
  18. sps170373
    Sounds good fletch, keeps us updated
  19. Skippy79
    I've had fairings from aucmarts before on my 07 blade, porbably the best fairings for the money they charge, painting was good, stickering also, fitment was decent, not the best, but I've had racefairings that fitted worse….
    get them one your bike and put some pics up!
