What Battery
Discussion in 'Maintenance' started by Agent Orange, Dec 28, 2013.
  1. Agent Orange
    Agent Orange New Member
    The book says that I need a YTZ7S to replace the unit on my 2010 ABS. The one fitted is marked YTZ10S.
    Anyone know the difference?
  2. sps170373
    The ytz7s is smaller in size and wouldn't be enough for your bike and is for non abs bikes! I have a ytz7s in my non abs 2008 bike
  3. ShinySideUp
    ShinySideUp Elite Member
    Don't think this has been posted in the correct section mate, as it's more suited to maintenance section but miby one of the mods could move it if they spot it.
    Anyway, as said the batteries have different physical diamentions along with the 7s only having 6amp worth of power and the 10s having 8.6amps.
    But besides these size differences the positive and negative poles are on different sides, The 7s has its positive pole on the front right but the 10s has its positive pole on the front left!
    So you couldn't just fit the larger of the two batteries to get more power from the battery as it won't connect to the bikes loom correctly.
  4. Agent Orange
    Battery
    Thanks
    I am going to buy a Lithium Ion unit for my 'bike and the people keep telling me that the YTZ7S is the one for all 'blades, despite the fact that I am shouting back that the one fitted to mine is a YTZ10S!
    Anyway, sorted thanks
  5. Bloy182
    Bloy182 Active Member
    I think a lithium battery is the only way forward.
    Ive seen bigger batteries on 125's, the stock one just don't cut it
  6. sps170373
    I've got a motobatt on mine at the moment which has been good but will change to a lipo next time
  7. Scott
    Scott Active Member
    Black n white bikes are doin a special offer on lightweight batteries if that helps
  8. Slick
    I got a Lithium one for my ABS deffo a YTZ10S.
    Now I've tried lithium I will never buy a Lead acid again, so much more cold cranking power!! Just need to leave the light on for a minute before starting in very cold weather
  9. Dec
    Dec Active Member
  10. Agent Orange
    Had a lithium YTZ14S on my VFR over the winter and no problems so wanted to gert one for my 'blade. I am going to now that I know the correct type.
    You can use a maintenance charger as long as it does not have a desulphating cycle. That will destroy a Lion battery and they can be revovered when totally discharges now. I think the mainstream battery manufacturers are bricking it so spreading negative rumours.
