European tour on an SP
Discussion in 'General 1000RR Discussion' started by DannyBhoy, May 10, 2014.
  1. DannyBhoy
    DannyBhoy New Member
    Afternoon folks,
    I am currently torn between taking my beloved SP to Europe this month or hiring a VFR1200 with full panniers, top box set up. The reason I posted this is because I have never had luggage on any previous bikes and my options seems quite limited if I was to buy some and take the SP.
    Any of you guys done long miles with your blades and what luggage setup did you use??
    Danny
  2. ColinBR
    Can the seat pad from a standard blade fit?
    If so here's what I go with. It's a rentec rack and Kriega US30. I've added a US20 to this also if needed for any longer stays.
  3. DannyBhoy
    Cheers Colin, Im pretty sure the standard seat pad will fit (will need to source one though).
    I looked at the Kreiga stuff earlier and it mentioned fitting without a rack but I was concerned about the straps rubbing against the tail. Is that why you plumped for the rack too?
  4. Garyb
    Garyb Moderator.
    I belive The SP has no subframe as such, well certainly not for a rack of any description.
    So either strap direct onto a venture shielded to death rear end body work? Or buy a rucksack.
    Or you could just sent the luggage ahead with the chauffeur ;)
  5. ColinBR
    If you don't use the rack you end up bending the seat up when you tighten the straps.
    You can get the rentec without the shelf type grill at the back if you don't fancy that bit.
    Essentially the rack is only needed for the straps to be tightened onto.
  6. ColinBR
    Good point Gary
    Danny you would need to make sure there are provisions for the rack first.
  7. sinewave
    Hire the VFR mate it's by far the best option IMHO
  8. ShinySideUp
    ShinySideUp Elite Member
    Would the lighter hole ridden subframe spars hold the extra weight of luggage?
    Just a thought as the non sp spars are also designed with carrying a pillion so would handle luggage weight as if its a pillion!
  9. Ritchierich
    Ritchierich Well-Known Member
    You'd have to fit one of them "Honda Comfort Seat" Danny, 3 hours a few week ago on my SP and I just can't describe how sore my ass was :-(
  10. Garyb
    Garyb Moderator.
    There isn't Colin, I'm not sure a pillion seat would be fitting either, as there are no provisions for two up.
    Seriously,I went through all this with Kevin at Preston Honda, a couple of months back.
    And due to the fact I couldn't tour with it as I wanted to, like my present blade and I had to let the chauffeur go due to cut backs I left it in the shop :eek:
    That said, there are some clever peeps around these parts, and I bet there's someone in the shadows with a good way of hitting this small issue?
  11. graemewalker
    graemewalker Elite Member
    Yes. As jay said a VFr will be a dammed more comfortable esp as sp sus is set up pretty hard I know which I would choose and nee flat spots on your tyres still a lot of straight roads before you reach twistys
  12. Alblade
    Alblade God Like
    Tour on the Blade - scratch on arrival, travel light, go to supermarkets to buy new clothes, throw the dirty ones away / give to the homeless
    Or use FlyBikeFly.com and jet into Nice to meet your bike
    Trust me - a blade is a perfect touring weapon...
  13. sinewave
    U can still have fun in the twisties on a VFR12
  14. martinowen
    The seats do fit, we tested at loomies last month ;)
  15. luker
    luker New Member
  16. Alblade
    Alblade God Like
    This is me after 2 weeks and about 3,500 miles in Europe to Mugello in 2010 - luggage never moved before anyone comments!
    Have since gone ventura and would prob. go Givi loc mount for tank bag
  17. wedgiewolves#223
    wedgiewolves#223 God Like
    Longest trip 3700 mile on my blade little bit of sore neck after a 700 mile day/night trip but sweet as . It had Harris clip ons etc same as I took it on track
  18. telski789
    telski789 New Member
    #18 telski789, May 11, 2014
  19. Dave V
    Dave V Elite Member
    I'd personally take the SP, somehow.
    Although agree that you could have loads of fun on a VFR, you won't know what your missing if you don't get the blade on those european roads.
    Before had the renntec I found the seat curling, what would we do without gaffer tape for a quick fix?[​IMG]
    #19 Dave V, May 11, 2014
  20. dessp2
    dessp2 Well-Known Member
    I have a long weekend in Cochem planned at the end of June . I would love to take the blade but my wife and two young lads are going aswell so it's gonna be the Nissan Qashqai.
    Whichever you choose have a great time.
