Hi Anyone got an infill panel for a anniversary model, just bought an Arrow can and need an infill anything considered Thks Dave
Some slight marks a gentle dust with black and they will go away No brackets just the panel http://1000rr.co.uk/showthread.php?t=18353 You'll see it on the above topic
The panel from a Scorpion exhaust might do the job,it fits very well against the lower fairing as there is a small lip so it sits flush. Bolts on thru the fairing bolt,you may need to make a bracket to steady it tho as the 2 underside fixings attach to the Scorpion can.
Hi Fletch, Thanks, but I think the growler will be too big, the scorpion one looks like it will be the one I need as the Arrow can I have is quite large. Cheers Dave
Hi mate, The scorpion looks like it would fit the best, is that a generic scorpion infill ? if not what can is that you have and I can ask Scorpion about buying an infill directly for that model. Thanks Dave
Hi all, Thanks for all the replies, I am now sorted with an Austin Racing infill which one I make up some brackets will sort the issue. Dave
