Which Chain n Sprockets
Discussion in 'Mods, Upgrades, Accessories and Products' started by TeZ, Jul 1, 2014.
  1. TeZ
    TeZ New Member
    I know... Yawn..
    I would like a gold chain (not sprocket)
    What do people go for? Brand? +1rear?
    TeZ
  2. ColinBR
    + 2 rear sprocket, and a Tsubaki X-Ring Gold chain.
  3. Womblewizard
    Womblewizard Active Member
  4. ColinBR
    Sprocket is a supersprox and chain is as above Tsubaki X-Ring gold
  5. TeZ
    TeZ New Member
    Nice I've had supersprox before they discolour after some time but good otherwise.
    Think I'll go for one again, I was worried the gold on gold on gold (wheels) may be to much, you've proven me wrong :)
    Any links to best place to purchase?
  6. ColinBR
    Speak to Andy at demon Tweeks mate. He'll give you a forum discount
  7. TeZ
    TeZ New Member
    Cheers for all the help guys!
    On it :)
  8. Dif950
    Dif950 Active Member
    Just what I'm looking for!
    Is this chain better than a DID one, and could you tell me what the advantage is of having a +2 rear sprocket please?
  9. foenix
    foenix Active Member
    If you want the best chain , buy an AFAM 3D chain, 525 . best chain on the market .
  10. TeZ
    TeZ New Member
    Well... Can only get Supersprox in 43t!! So it may have to be Renthal.
  11. ColinBR
    That's what I have on my bike mate. Still give you that little extra out of the corners without loosing too much fuel consumption.
  12. Dif950
    That's good enough for me then! The sprocket only comes as a standard size?
  13. TeZ
    TeZ New Member
    Ah interesting! Standard front 43t rear?
    Do you have standard link chain Colin?
  14. ColinBR
    Yes standard front sprocket and the 43T rear.
    I used the chain link that came with the chain, and riveted it on using a chain riveting tool.
    If you don't have 1 or are not confident in doing it yourself, get a local mechanic to do it for you. Not worth the pain (literally) if the chain snaps because of a ill fitted link.
  15. ColinBR
    43T is +1T compared to standard.
  16. Dif950
    Brill. Thanks Colin
  17. TeZ
    TeZ New Member
    Yep thanks Colin.
    I'll be fine with the fitting just didn't want to spunk ~£200 on the wrong gear :)
  18. ColinBR
    Mind and speak to Andy at Demon Tweeks for a discount ;)
  19. RepsolPaul
    RepsolPaul Well-Known Member
    Going 1+ or 2+ on the rear, how does it effect the top end and speedo. ?
  20. Dif950
    Yep, it's becoming a habit..
