Garage floor
Discussion in 'Lounge' started by Stevie_d, Jul 8, 2014.
  1. Kentblade
    Again, it appears there is a thing called laitance you need to be aware off, I gauged that my floor was just bloody dirty rather than suffering from this illness, and like yours its been down a long time, 40 years in my case. So I could see no need to seal it, just made sure it was a clean and dust free as poss. the surface was free from any damage or flaky areas.
    So far, so good, it's dry and appears to have stuck like the proverbial to a blanket, obviously only time will be the true test of its durability.
    Again my reading up suggests any new concrete is left 6 months to a year before painting.
    But as I am only a google expert on this, and not a builder I really don't have much of a clue mate.
  2. Womblewizard
    Womblewizard Active Member
    Can't find it on wickes website but screwfix do the same thing as in previous post!
    Do a no nonsense tin for 17 quid got good reviews!
    Product code 74591
  3. Kentblade
    Steve, as requested, taken under fluorescent light
  4. restone
    restone Active Member
    I'm a builder and my best advise is
    Hoover it big time
    Get some concrete floor hardener from builders merchants you mix it with water and poor on with a rose sprinkler on a watering can. You will need double what they recomend so give it 4 coats 1/2 day drying in warm weather between coats. Stops dust and paint blistering
    %50 solution of pva 2-3 coats then paint it with an oil based floor paint as previously advised by another member.
    The bumps and bobbles will wear eventually so better still
    Make a 50% solution of SBR cement polymer aditive made into a slurry with neat cement and liberraly slop it all over( Builders merchant) pricey but the dods diddies
    Once tacky put a self leveling sceed (rubberised one is best)= perfect level clean dust free floor
    Or just stick heavy duty lino down;)
  5. mr.h
    mr.h Active Member
    My floor is about 30 years old - hoovered really well, and hit it with 2 coats of Trade group grey floor paint - plenty of outlets (mainly trade)and the garages use it so no bubbling when you park up with hot tyres.
    Still looks good after 3 years of use.
  6. restone
    Thats a damn good floor and paint to last that well, resprct.......I'd wager the original concrete had plenty of floor hardener in it when poored
  7. Freedom of choice
    [ I'll pretend I don't know it's not 100% level my OCD will never know !![/QUOTE]
    I doubt it....... but if you can sleep at night, happy days.
  8. ozzer76
    ozzer76 Member
    I have the commercial vinyl you find in school corridors and such like. Managed to get a free roll and it's great. Plus no wear and reprint needed. Painted the walls white but now thinking the walls need jazzing up a bit! Red stripe or something to just make it more interesting. Mmmm
  9. Ratser
    Ratser Well-Known Member
    Thanks to Colin on here highlighting the good prices, I got some of the jigsaw flooring from Halfords and installed it throughout.
    I would watch with painting it to make sure you get a textured paint so that it isn't too slippy.
  10. Stevie_d
    Stevie_d Senior Member
    Flooring looks good how much was it that halfords stuff ?
  11. Ratser
    Was £10 for 1.6 x 1.8m worth per pack.
    They had it on special at the time.
    Weight of the bikes does compress it a bit though, and we have the stands on pucks as well. Especially the 600RR as the stand is just a small square end.
  12. Stevie_d
    Tomorrow's job , no white lines tho !
  13. Stevie_d
    Well first coat done today, really highlights how shite the floor is but as long as it cuts the dust down ain't too bothered. Next up is painting the walls white, then some freebie kitchen units & cupboards
  14. jimglasgow
    jimglasgow Member
    It's hard to ignore the carpet :)
  15. Stevie_d
    Yeah I'd already bought the paint, reckon the rubber matting was good from halfords as well, will see what it's like when the lots complete, may put orange carpet down on top of it lol
  16. Repsol Rob
    Repsol Rob Elite Member
    Hey Steve the cover looks good......... ;)
  17. Stevie_d
    Plus point is your cover Rob ! Need the surroundings up to that standard lol better when walls painted. Anybody know the repsol orange colour code lmfao
  18. Ratser
    Think it's called "Slow Orange" ;)
  19. Fudster
    Fudster Active Member
    You forgot the code for it === 510VV
  20. Stevie_d
