New ZX10
Discussion in 'Other Bikes' started by Bikeracer1098, Jul 7, 2014.
  1. Waterblade
    Waterblade New Member
    The ZX-10R is the most aggressive looking bike I've ever laid my eyes on. I'm even afraid to approach one.
  2. sinewave
    Crock O shyte!
    Wouldn't touch one with a barge pole! ;);)
    #22 sinewave, Jul 9, 2014
  3. Bikeracer1098
    Bikeracer1098 Active Member
    Lads who race them on trackdayriders tell me that the front end is superb, but the rear end requires a lot of modification to get the bike to handle well. Also said that the gearboxes are weak but replacing the gearbox is straight forward as it is a cassette gearbox
    Is that so?
  4. Mad Matt
    Ive heard the same about the gearbox, apparently the 2011 onwards isn't as solid as those before it however i don't believe this is any different from that of the Blades gearbox. I had issues with mine so does Jay and Jase's went altogether. Imo there is a very small chance of you getting one with a not so perfect gearbox but you are correct, I spoke to J&S and they have a cheap but extremely good fix if you were ever to have issues...
  5. sinewave
    I've found mine brilliant in standard'ish and modified form on Track
    Blade is better for the road if your tour or commute due to the superior tractability of the engine
    Latest ZX10 was only around half a sec behind an SP around Mallory when Rutter tested them for a Magazine
    The ZX was on shyte tyres and an overheating rear shock plus standard BPF Showas up front!
    Waz full Ohlins, Brembo calipers and Pirelli Super Corsars on it to level the playing field and.......................
    :cool:
  6. Bikeracer1098
    Bit pointless testing superbikes around Mallory Park.
    Mallory is better suited to small bikes.
    Thanks for the info regarding your bike
  7. arthurbikemad
    Yep full cassette gearbox, like the 4-7 blade, RSV4, F41000, ZX6 etc
  8. scooby
    scooby Elite Member
    it amazes me why all bikes,especially race focused bikes dont all have cassette boxes.can only assume it's an engineering issue,even honda went back from 08 :(
