Quick flash.
Discussion in 'Mods, Upgrades, Accessories and Products' started by bradt, Jul 13, 2014.
  1. bradt
    bradt Elite Member
    I want to change the rear indicators to some smaller one's are all replacement ones going to flash fast ?
    I don't want to start buying 'extra bits' to get the flash rate correct.
  2. GBCS
    GBCS Active Member
    I fitted one of the Motodynamic integrated rear lights this afternoon.
    Works straight out of the box, and looks the business.
  3. Dano28
    Dano28 Active Member
    Mine did when I fitted R&G mini indicators but two resistors later all sorted, it's a 2min job mate.
  4. sps170373
    Depends on if you get led or bulb type indicators, led's tend to flash quicker and need a relay or resistors to slow the flash rate down
  5. Garyb
    Garyb Moderator.
    Brad you tease ;)
  6. Stevie_d
    Stevie_d Senior Member
    No pics ?
  7. Ade
    Ade New Member
    I've just bought some R & G mini indicators bulb type and they are flashing faster than standard
    I didn't think there would be an issue with the bulb type that was why I bought them.
    Does anyone have any idea's?
  8. Barstewardsquad
    The problem with faster flash rates is because of low power usage and not necessarily the bulb type. If the bulbs you have are a low wattage you will either need in-line resistors or a new relay, personally I would go for the relay on 06/07 models as it is located behind the left fairing and is easy to get to.
  9. Ade
    Ade New Member
    The standard bulbs are 21W the R&G bulbs say 12V0.5W H21W
    If i'm going to need a different relay do you have any idea what type and where would I buy it from?
  10. Barstewardsquad
  11. Dano28
    Had same issue phoned R&G and they sent me some resistors if I remember.
  12. Ade
    Ade New Member
    Just got my new flasher relay as recommended by Barstewardsquad and it works a treat so cheers for that.
    I do wish that the suppliers of after market gear would make it clear if extra things are required to make there product work, don't mind paying for it just want to fit the gear and ride the bike.
