2008 Race Blade with irratic idle??
Discussion in 'Maintenance' started by muckster, Jul 31, 2014.
  1. muckster
    muckster Active Member
    Hi All.
    I've a blade with HRC loom and ECU that has an idling issue.
    If I start the bike in the garage it idles at 2k rpm no problems.
    After a session if I pull the clutch while still rolling with the bike in gear it idles at 4k rpm and eventually drops to 2k rpm.
    The throttle isn't sticking and neither are the throttle bodies as I can hear them snap back when stationary and as I said it never does it when parked.
    I've checked that the throttle bodies are seated right, and all the vacuum pipes are ok..
    I'm thinking a loose connection or broken wire but not sure what part of the bikes electrical system could give this problem.
    Otherwise the bike is running perfect!!
    Any ideas??
  2. Carlo
    Carlo Active Member
    Is the air filter seated right? any cracks in the air box? A Renault 172 came into the garage i was working at years ago with a really hight idle so i sprayed a load of brake cleaner over the inlet manifold and found it was cracked but only a hairline underneath and it was pulling in air after the filter causing it to idle funny/high then the ecu realised and cut the revs back down drove fine as well just when rolling off the throttle when you dipped the clutch in you could notice it
  3. muckster
    It seems to be fine. All screws in place And seating fine. I'm going to pull off the throttle bodies again so I'll double check the airbox too.
    Im a bit baffled as I don't know if its air leak related or electrical.
    Also I've no dyno or track near by so no way of testing it either
