rr4 - Romving pillion pegs - heatshield bracket ?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Fastmonkey, Jul 2, 2014.
  1. Fastmonkey
    Fastmonkey Active Member
    Looked at removing my pillion pegs on my new RR4 last night but the right side one is also the hanger for the exhaust heat shield. I still want to run the heat shield and looking at some old threads see there was an aftermarket bracket available, but I can't find one for sale through ebay or search.
    Any ideas ?
  2. BoroRich
    BoroRich Elite Member
    I've got one of the eBay ones on my RR4. Looks like they aren't for sale anymore. Only thing I can think is to make your own.
  3. martinowen
    I cut a spare peg down, sprayed black and it looks like I was always that way
  4. martinowen
    Can kind of see it in this pic
  5. Fastmonkey
    Yeah looks like they aren't available anymore.
    @martinowen - that's a very neat job, nice work. I think that's the best route to go down.
  6. Pete H
    Pete H Active Member
    I did the same, went home made, but I found the bracket thing that some bloke was selling on eBay and used a picture as a template, then spent an evening dremmelling a piece of thick black plastic into the same shape, works a treat.
  7. garyauk
    garyauk Active Member
    I cut down a very small piece of dexion and put 2 kinks in it. then removed the outer heat shield (carbon shield above) and attached it to the inner heat shield bolt and then put the outer heat shield back on with a small nut behind
    Very neat and tidy as you don't see it
  8. johnd
    johnd Active Member
    I have one fitted to my bike. I can remove it and take a pic if you want to try making your own?
  9. Fastmonkey
    Cheers for all the replies and @johnd for your offer, but a kind member has pm'd me with a bracket for sale so I'm all good.
    I'll take a pic and post it when it arrives in case it helps others.
  10. Fastmonkey
    Here is the bracket for anyone interested.......
  11. StanleyRR
    StanleyRR New Member
    If anyone else happens to have one for sale id be interested too. Failing that make one like above :(
  12. Regenwulf
    Regenwulf Active Member
    I just remove the hanger, drilled a small hole in the shield, cut a thread into it and put the bolt back through with a washer.
    It is holding well, heat not causing any issue and looks a lot neater.
    RW
  13. dave d
    dave d Elite Member
    Black cable tie.....job done!
  14. StanleyRR
    Not keen on pikey fixes im afraid
  15. Barstewardsquad
  16. jpsrepsol
    jpsrepsol Active Member
    Spot on saved me looking through post to find this as next thing on my list
  17. PazzoTazzo75
    PazzoTazzo75 New Member
  18. PazzoTazzo75
    ImageUploadedByTapatalk1409678817.036013.jpg ImageUploadedByTapatalk1409678829.368339.jpg i removed the pegs today. 2 minute job and the eBay adaptor thingy seems decent!
  19. Barstewardsquad
    And sold out now! Guess I will just have to wait and see if he does some more.
  20. PazzoTazzo75
    Send him an email, I'm sure he's not going to turn down money!
