Rear Hugger
Discussion in 'Mods, Upgrades, Accessories and Products' started by Hoppy, Sep 12, 2014.
  1. Hoppy
    Hoppy New Member
    Hi guys,
    It may have already been discussed, but has anyone had any success with fitting a hugger to an ABS version?
    Cheers,
    Hoppy.
  2. sps170373
    You can fit one but I would suggest getting your suspension set up first, as it when the suspension compressed that the abs housing makes contact with the honda full hugger.
  3. Stevie_d
    Stevie_d Senior Member
  4. Stevie_d
  5. Moon
    Moon Active Member
    I had success in fitting a carbon version of the small standard one...
    Then success in smashing it about 16 miles up the road when I bottom out the rear end
  6. Stevie_d
    Shoulda banged the rear shock preload up a few notches
  7. sinewave
    Do a search matey, it's all there and all doable
  8. beavis
    beavis Active Member
    My mate had the abs model , he had an R&G hugger on it.
  9. Hoppy
    Hoppy New Member
    Thanks guys, I think I am going to go for the R&G one. Pics to follow when I get home in a few weeks....
  10. rebel
    rebel Active Member
    what and fuck the handling up just so you can fit a rear hugger.
  11. RRoss
    RRoss Active Member
    No issues at all with my R&G hugger on a 2012 model ABS:)
    Quite fancy the carbon fibre one to match my front mudgaurd but a lot of money if i do smash it:eek:
  12. Stevie_d
    If yer bottoming out the suspension then it ain't set right , so my guess would be the preload ain't right to start with.
    Needs setting up correctly. Mine had to go from the standard 4th notch to 7 to get the sag right on the rear shock.
    If that ain't right then the rest of the suspension wants setting up as well.
    Been on some really bumpy road where the bike has left the ground completely , mine ain't bottomed out or smashed me hugger ................................
  13. rebel
    rebel Active Member
    fair point i got a abs model and quite fancy a hugger but its the bottoming out bit thats putting me of theres people on here
    with there suspension set properly and they have still smashed there hugger.
  14. BladeJogger
    BladeJogger Member
    R&G hugger on my abs 2012 bike works fine,fitting it was a pain mind,the bolt holes didn't quite match.
    #14 BladeJogger, Sep 14, 2014
