Bleeding abs
Discussion in 'Mods, Upgrades, Accessories and Products' started by p88sow, Oct 20, 2014.
  1. p88sow
    p88sow New Member
    Iv got abs pipes to change on my 2012 blade.... do i bleed it the same way as a non abs brake system, iv had to change the two pipes that run from the abs pump up the frame due them having a crack and weeping....
    All help appreciated
    Pete
  2. ColinBR
    Unfortunately you have to do the full ABS bleed procedure.
    Other option to fitting replacement OEM lines is to fit HEL ABS lines which are stainless steel and won't rust.
  3. p88sow
    p88sow New Member
    Whats the full abs procedure ? any online manuals to do the procedure
  4. JWRusk
    JWRusk Active Member
    the search function will guide you
  5. Slick
  6. thezipsteruk
    thezipsteruk Elite Member
    Sorry! sorry wandered in here thinking the title was a statement!!
    :D
  7. p88sow
    p88sow New Member
    Thanks for the help slick, appreciate it, ill give it a shot tomorrow wish me luck...
