Iv got abs pipes to change on my 2012 blade.... do i bleed it the same way as a non abs brake system, iv had to change the two pipes that run from the abs pump up the frame due them having a crack and weeping.... All help appreciated Cheers Pete
Unfortunately you have to do the full ABS bleed procedure. Other option to fitting replacement OEM lines is to fit HEL ABS lines which are stainless steel and won't rust.
definitely change them for braided but yes you will need a full abs bleed. look here for detail http://1000rr.co.uk/maintenance/16292.htm
