L.E.D security light
Discussion in 'Lounge' started by Stevie_d, Nov 24, 2014.
  1. Stevie_d
    Stevie_d Senior Member
    Anybody recommend a good one to mount in the back garden , with p.i.r
    Brighter the better , but not hundreds of pounds ?
    Steve
  2. Remal
    I have 2. a LED solar one I bought via costco which has been great until recently and why I've turned it off for now. With poor sunlight it only lasts about 2 hours
    this one in black
    Costco UK - Sunforce Solar Motion Sensor 80 LED Security Light
    But I have had at the bottom of my garage another that's powered and I've had about 3 years and works great. But I don't know what make or model it is. Just a LED with PIR
    I've fitted for mum this one XQ Lite LED PIR Floodlight 10W Black | LED Floodlights | Screwfix.com and it may be only 10W but it's more than enough to light up her pathway, driver and other houses when on and comes on up to 8M away
  3. Remal
  4. Kentblade
    I looked at replacing a 150W halogen with one of these, decided I would have to use a truck of electric to just break even, so bought a new 150W bulb instead.
  5. Remal
    The one's I posted above where a straight replacement to the old PIR security lights I had
  6. Stevie_d
    Just wonder if 30w led is bright enough ?
  7. sps170373
  8. Remal
    the 10W my mum has is more than enough for her and it covers a large car park area and pathway so 30W would be more than enough
  9. Pete1987
    Pete1987 Active Member
  10. Remal
    Same as I posted above. you hear 10w and think thats not enough but unless you have a area the size of a park to light they do a great job
  11. Repsol Rob
    Repsol Rob Elite Member
  12. Repsol Rob
    I guess the 30watt one is mounted at high level........ if its around 2.6 to 2.8m you might want a less wattage and also the higher you go the less PIR coverage you ll have..... unless PIR is designed for higher mounting height.....
  13. Stevie_d
    Cheers rob , but just ordered the 30w one from screw fix hope it's better than my yellow looking 500w halogen
  14. The.kickboxer
    The.kickboxer Active Member
    30w will be loads, I have one of the 10w ones with a battery and it will burn ur bloody eyeballs out if you accidentally look at it.
