CBR1000RR 2010 bi-xenon projectors
Discussion in 'Mods, Upgrades, Accessories and Products' started by tgosai, Dec 3, 2012.
  1. ShinySideUp
    ShinySideUp Elite Member
    Jbully, a standard H7 headlight bulb is 55w so wouldn't draw any more power than the stock bulbs!
  2. Jbully_uk
    Jbully_uk New Member
    Looks like Hump is the only one and he makes them up on order from what I can see :( to behonest honda should put them as standard makes the bike look the dogs
  3. hump333
    hump333 Member
    I have projector lights here to fit 2004 /07 ready made Black style. And just in middle of making set up for k7 gsxr[​IMG][​IMG]. [​IMG]If anyone needs a set order the right kit and I'll fix up. Or send me cash and I'll order them no problem
    #143 hump333, Jan 14, 2014
  4. hump333
    hump333 Member
    K7Gsxr bi xenon projector lights and halos [​IMG]
  5. Bloy182
    Bloy182 Active Member
    Hump
    Would you sell all parts required to convert the 2008 blade headlight? I would give this ago on mine
  6. hump333
    hump333 Member
    Your best off buying from ebay mate cheaper. Full bi xenon projector lights kit. Around 60 to 100 depending on model n type of kit you buy.
  7. nambiker
    nambiker Active Member
    [​IMG] [​IMG]
    thanks hump333, its been a long time sitting in the garage but the lights are almost ready to go! all i need to do is hide all the wires and put everything back together!
    #147 nambiker, Jan 21, 2014
  8. hump333
    hump333 Member
    Nambike they look spot on mate mat black with black paint work is a must.
    I have done your cousin ( Lee H ) Gsxr lights. Thanks for passing my details on much appreciated Nam ;-)
  9. Bloy182
    what size are the bi xenon hump? 2.5"?
  10. hump333
    hump333 Member
    2.5 yes I have 3 in my bike
  11. Bloy182
  12. hump333
    hump333 Member
    Not really the shape of them will hit the chrome reflector
  13. Bloy182
    meh, dont suppose you have a link where i can get some? ;)
  14. hump333
    hump333 Member
    These a better bloy
    231018765425
  15. hump333
    hump333 Member
    What year is your bike?
  16. Bloy182
    2009,
    The listing you showed me is that all I need parts wise?
    So the dipped beam and angel eyes come on together?
    I noticed the shroud on the near side light is different as it holds a
    Main beam bulb only, do you need to cut anything to get the
    New ones to fit?
    Thank you for your help
  17. hump333
    hump333 Member
    Bloy that will unscrew when u have unit the unit apart. You will 12v waterproof switch. An 500cm extension as well. Velcro fastening to stick your ballasts down n hids
  18. callumw
    callumw Active Member
  19. lambchops
    lambchops Elite Member
  20. Pete1987
    Pete1987 Active Member
    Dont get 8000k ones the light output isnt very good (very blue light) if you want to do it go for 6000k or 4200k they will give much better light outputs (6000k is daylight white, 4200k is a more yellow light).
    Our eyes aren't designed to see blue light very well.
