Bike upgrade!
Discussion in 'New Members' started by Karlos, Dec 14, 2014.
  1. Karlos
    Karlos New Member
    Hello!
    My lovely high-mileage 2002 blade developed a few engine issues recently so I picked up a 2010 1000RR-ABS this morning with only 2k on the clock and finding it rather nice :)
    I've had a few CBR600's and a couple of blades now, I do look at other models of bike but always end up with another CBR!
    Done a few track days at Brands Hatch, Lydden Hill and Almeria in Spain although I only really ride for commuting these days.
    The seat on the new bike is a little high for me and quite slippy so I'm thinking about lowering the suspension and getting a Honda e-cushion seat.
    Does anyone know whether lowering the suspension by a few cm makes speed bumps a problem?
    Sorry for the crappy pic - it's dark, wet and horrible outside! (but I've been out for a little blast anyway)
  2. Mr OCD
    Mr OCD Well-Known Member
    Good choice ... Same as mine but I don't have ABS.
    How do you find the fueling at low revs / small throttle movements?
    Get some tank grips ... Helps with the slippy seat but also stops you scratching the paint on the tank ...
  3. red5
    red5 Well-Known Member
    Hello and welcome.
  4. M3NTALIST
    M3NTALIST New Member
    Nice bike and welcome to 1000RR.
    Andy B
  5. Eal77
    Eal77 New Member
    Hello and welcome to the forum.
  6. marco s
    marco s Active Member
    Hi and welcome . .
  7. RepsolPaul
    RepsolPaul Well-Known Member
    Hi and welcome, what part of London are you ?
    I'm South East.
  8. Barstewardsquad
  9. bradt
    bradt Elite Member
    Hi Karlos, welcome to the forum, good to hear that you got out on the bike tonight. Good man !
  10. sps170373
    Welcome to the forum mate
  11. madfish2001
    madfish2001 Active Member
    Hi and welcome. Nice Blade you have there.
    I can't answer your question about suspension, but I'm interested in hearing the reply
    as I also find the seat a little high on my 2013 Blade.
  12. ccr32
    ccr32 Active Member
    Welcome from a fellow London Fireblade owner :)
  13. Knighster
    Knighster New Member
    Welcome mate. Great, lively forum here. You don't need a lowering kit for the blade. Get a pair of these beauties. Plus you get the proper 'shit kicker' look. Absolute quality.
  14. Beckers
    Beckers Elite Member
    Hi n welcome buddy
  15. Karlos
    Karlos New Member
    Thanks for the warm welcome guys.
    I read up on the suspension linkage changes and it sounds like the front forks would need to be dropped a little at the same time, and possibly have the side-stand shortened. That's a bit of work just so I can get the seat lowered and have a comfy seat as well. I might just go for cutting a little seat foam out although I'm not in a hurry to do anything yet.
    The first corner I took at any speed just scared me a bit like I was riding a tall unicycle with a well waxed seat! I felt a bit more at ease today so maybe it's just a bit different and I'll get used to it.
    Mr OCD - I've not really noticed anything about the response at low revs so far. Do you have a mod in mind?
    The only thing that I have noticed at low speed is a small jolt when pootling along in 1st and going from drive to idle and back.
    RepsolPaul - North London
    Madfish2001 - I'll let you know if/what/when I do anything about the seat height
    Knighster - Thanks for the tip, but I'll pass on the Gene Simmons' little brother look :)
  16. BlackDevil
    Hi and welcome!
  17. rewy..rr
    rewy..rr Active Member
    Welcome
  18. Mr OCD
    That's right going from open to closed throttle in 1st and 2nd results in shunting ... Holding a tiny bit of throttle in those gears at low speed also causes the same issue ... I.e. Commuting through heavy traffic ... At least it does with mine hence the question :) ... Pretty common apparently... And an issue I'm getting sorted.
  19. Rr-Len
    Rr-Len New Member
    Welcome nice new blade
  20. graemewalker
    graemewalker Elite Member
    Slip the clutch for me all day
