Braided Lines on an ABS model
Discussion in 'Mods, Upgrades, Accessories and Products' started by BladeRR8, Jan 13, 2015.
  1. BladeRR8
    BladeRR8 Active Member
    Has anyone done this ?
    I have always fitted braided lines on all my bikes but this will be my first bike with abs
    Is it worth fitting braided lines to an abs bike ? If yes has anyone done it and was it a real pain to bleed due to all the extra hose and abs pump increasinv potential air locks.
  2. sps170373
    Colin br has done it and a few others, the thread will be in the search forum
  3. BladeRR8
    Cheers for the reply.
    I tried the search function with no success. I mustn't be able to see wood for trees will have to try the search again
  4. ColinBR
    Yes we have done it, and yes it is a bit of a pain in the ass to bleed. What year of bike have you got mate?
  5. BladeRR8
    Its not here yet just planning my mods in advance. Expect it next week. Its a 63 plate Zx10r but not completely gone to the dark side still got the SP2.
  6. Julian
    Julian Active Member
    intend to fit/have fitted HEL's that I bought off Arthur a while back, my bikes due it's first fluid change, if you've got any hints or tips it'd be most appreciated Col
    (2012 abs model)
  7. ColinBR
    It will be a different way of bleeding that system. You would need to ask those in the know.
  8. ColinBR
    Best thing to do is ping SwissT a pm mate, as he has bled his ABS on more than a few occasions and has it down to a T.
  9. BladeRR8
    Cheers Colin
  10. Slick
    I've done it
    http://1000rr.co.uk/mods-upgrades-accessories-products/13373.htm
    There was an improvement to the OEM setup but I also added an RCS, did a full bleed, fully serviced my calipers and had my suspension upgraded so couldn't say the lines was the main contributor.
    Worthwhile if your OEM lines are old/tatty but don't expect night/day improvement.
  11. sinewave
    Fitted em to mine but the Dealer bled the system and had a Mare by all accounts!
  12. ShinySideUp
    ShinySideUp Elite Member
    The zx10r abs system makes use of a conventional type brake system and bleeding on such is done as you would a bike without abs and as such braided lines would give feedback changes at the lever similar to a non abs bike would.
    Only Honda's dumbass attempt at abs with c-abs uses a brake by wire system which IMH caused more issues than it ever solved!!!
  13. Dannymc
    Dannymc Active Member
  14. JWRusk
    JWRusk Active Member
    my Hel lines seemed to be almost to long for my bike. Not sure why, but i made it work
  15. graemewalker
    graemewalker Elite Member
    You could not pay me to have a abs,yes I know it is standard now but won't be changing my bikes from now,and if I was to get another it would be my first mod to convert to conventional lines like I did to 600 rr
