Aftermarket exhaust shield
Discussion in 'General 1000RR Discussion' started by Shane_L, Jan 17, 2015.
  1. Shane_L
    Shane_L Member
    Can anyone suggest where I can get a exhaust shield from for my 2012 blade? I've had one supplied with my austin racing exhaust but it's an awful fit and I'm a perfectionist. I like the yoshimura ones but can't find a 2012 onwards anywhere.
    Thanks in advance.
  2. sps170373
    Just keep looking on ebay and here, they pop up occasionally
    Moorespeedracing.co.uk might be able to source
  3. stuart_g
    stuart_g Active Member
    You can get them from Scorpion exhausts. I have one on my 2012.
    You may have to make brackets to attach it though if you are using a Austin exhaust. The scorpion one fixes to the frame where the belly pan fixes and also it is drilled to fix to the scorpion silencer box that goes under the engine. This is where you may have to make something.
    I am well impressed with the fit and the quality of their infill.
  4. Shane_L
    Shane_L Member
    Thanks for the help. I will look into scorpion. I've also contacted racefit to see if they could supply me with one.
  5. sps170373
    The racefit one part connects to the frame and part to the exhaust
  6. N_Collins
    N_Collins Active Member
    I've just put a racefit one on me SP!!
    It fits to the frame & a lower fairing/bellypan bolt but you will have to fettle with it poss cut it to accommodate the link pipe!!
  7. N_Collins
    Not the best pics but gives you an idea! Hopefully!!
  8. Shane_L
    Shane_L Member
    That's exactly what I want N Collins. I have contacted racefit about that one. On there website it says it for 2014 onwards but I thought they were the same from 2012 onwards. Yours looks like the same factory panel as mine. I would upload a pic but don't know how too on here with my iphone.
  9. N_Collins
    The 14 is different to the 12 as the exhausts are different!!
