Hi guys anyone know why and how to stop pics from turning on uploading? Is it an iphone/ ipad things as thats what im using?
Is it maybe something to do with autorotate on the ipad and you are using it 180 degrees out when uploading pics???
Try taking a photo with the phone held 180 degrees from how you normally take it sounds darf I know then try uploading it, I had similar problems till I worked out which way to hold it
Are you taking pics of things with the phone held flat (horizontally) or almost flat? If so the iphone gets confused about which way is up. 'Edit' the pic on the phone by 'rotating' it so it appears right way up when you look at it held vertically. That tells it which way is up.
I have uploaded pics via my phone and tapatalk and laptop without a issue. it's probably something to do with when you take the pics. Sometimes mine have gone on the side but it was how I took the picture. So I just rotated them the right way
I would not have thought it would be how they were taken, they are correct way up in my photos when I upload them onto here.
Why Your iPhone Photos are Upside Down & How to Fix That Why does my iPhone take upside-down photos? - CNET https://discussions.apple.com/message/16514340#16514340 I should have added to this, as I posted above, if you take iphone pics of something with the phone held horizontally (flat, pointing down, or in roughly that position) the phone gets confused about which way is up. You can always 'edit' the pics and rotate them any way you wish afterwards if when viewed they appear wrong way up.
