Hunting Idle - Yoshi R77
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mr OCD, Feb 6, 2015.
  1. Mr OCD
    Mr OCD Well-Known Member
    Anyone know how much fuel to add to the power commander at 0% throttle to resolve the hunting idle?
    I've dialed in '3' which has helped but its still not quite right.
    Ideas?
  2. Mr OCD
    Figured it out you useless gits ;)
  3. Barstewardsquad
    and the answer was? :p
  4. Mr OCD
    Go and work it out yourself... nobody else bothered to help!
    :p :D
  5. Freedom of choice
    I wouldn't say they are useless , the other part however...........
  6. Cookie42
    Cookie42 Active Member
    Hi ocd , could you send me a copy of your map to try on my bike. I've got the hunting idle with a r77 fitted.
    I just want something to tide me over until I get a custom map done
    Would you recommend fwd ?
    Thanks.
  7. Hudson
    Hudson Active Member
    Have you considered ringing Richard at Dynojet uk in preston ? I had my PCV fitted to my CB1000R and a custom map done by Richard and its just perfect, all the hunting at idle, surging at a constant throttle etc has gone for good.... he expained what and how he did it all... went right over my head, but he knows his stuff !
  8. Mr OCD
    Already spoke to them mate hence its sorted now. The bike is going back to Frank or Richard very soon ;)
  9. Mr OCD
    Send me email address.
    Yep I recommend FWD highly ... They have sorted all my bikes and always been spot on.
  10. Mr OCD
  11. ccr32
    ccr32 Active Member
    Ahh, come on! I was wondering what to dial in myself to fix the same issue on mine :)
  12. Mr OCD
    :D
  13. Si.
    can you mail me the settings for the low down idle please dude?
  14. Mr OCD
    Basically if you have a power commander fitted you need to raise the fueling at 0% throttle due to lack of back pressure in the exhaust.
    Adding fuel between 750-1500rpm is where you need it. I started with 3 in these rpm blocks but landed up at 10 after speaking to a tuner.
    The video is with them set at 10... You may get away with less so a bit of trial and error is needed :)
  15. Gilesy
    Gilesy Elite Member
    great idea.. I have the same hunting issue due to the race exhaust..
    #15 Gilesy, Feb 7, 2015
  16. ccr32
    ccr32 Active Member
    Are you running the Yoshi with or without the baffle Scott?
  17. Mr OCD
    Without baffle ;)
  18. ccr32
    ccr32 Active Member
    Thanks for the tips before - given it a go with mine this evening to not much avail I'm afraid. Tried adjusting those rpm blocks in 3 point increments from -10 to +10, and the richer I make it (+10) the worse it seems to run.
    Now it's stopped and I'm sat out here with the bike, smells very fuelly and rich! So maybe that is my problem...
    I also inadvertently hit reset on the throttle calibration window too which meant winding it to the stop whilst running to readjust... sorry neighbours, oops!
    Anyone know what the Duty % means? I've noticed mine is always around 2 at idle but can't find anything in the PCV help files that tells me what that means...
  19. Mr OCD
    Fuel Duty simply means % of injector capacity ... Nothing to worry about unless goes above 90% duty which on a NA engine is very unlikely.
    +10 is rich definitely ... I've actually turned mine down to +6 now. It's worth noting fueling doesn't stabilize straight away but can take a few a couple of runs ... I've no idea why either!
  20. ccr32
    ccr32 Active Member
    Huh... maybe I shouldn't have been so hasty in putting the standard Yoshi PC map back on then! To be fair, it's not that bad anyway, I'm just being a tart about it.
    I'll just do what I'm sure someone will recommend to me in a minute - book it on a dyno then JFRI! :)
