squeak rear linkage ?
Discussion in 'Maintenance' started by bladeaddict, Mar 13, 2015.
  1. bladeaddict
    bladeaddict Active Member
    Currently ride a 2013 model only had it a few months. Noticed occasionally a squeak from what appears the rear linkage area when I sit on it. Only weigh 13 stone. Is this area under greased at the factory? Any quick fix that does not require removal of rear shock?
  2. RRoss
    RRoss Active Member
    Mine did this for a bit too but it went away on its own. Only ever noticed it when bike been sitting in garage,never out and about.
  3. PeterT
    PeterT Active Member
    Mine also squeaked, cured by stripping it down and using more grease than Honda. Now silent
  4. PeterT
    This is where the noise comes from
  5. bladeaddict
  6. sps170373
    You only need to undo a couple of bolts to do that, Honda must be really tight on using grease
  7. PeterT
    Yes they are, my needle rollers were almost dry and had rust on some of the needles!!
  8. PeterT
    Now re-greased, you can see the wear on the edges as it touches the linkage plates
  9. Mr OCD
    Mr OCD Well-Known Member
  10. PeterT
    No, once a year, it was built for riding.
    Now on 21000 miles.
  11. Mr OCD
    I do 12,000 a year ... I still wash it every week :p
