What's the thought on cheap levers?
Discussion in 'General 1000RR Discussion' started by exuptoy, Apr 25, 2015.
  1. exuptoy
    exuptoy Elite Member
    I've had Titax levers a few times and Pazzo's but I've also had quite a few sets of Chinese stuff until the last bike (Gixer 1000 K5) and there was a big hoohar regarding them not being engineered correctly causing the gradual application of the front brake until it could throw a rider off!
    Are there any similar issues with the CBR1000RR (09) ones or should I just stick with the proper ones? Thinking of trying Accossato ones maybe?
  2. N1xxl
    N1xxl Member
    You pays ur money! I have used these and genuine levers on all forms of bikes without a single issue except where I mucked up. It is difficult to spot the difference and whi knows where ur genuine lever is made. Fit it correctly and ensure it has sufficient free play and all should be good. IMO it was a particular brand and model but I was not there so all speculation.
  3. sinewave
    I've used Cheap Ching Chong Chang Levers on my Track Bike for quite a while with no issues.
    Only swapped em out as I upgraded to a Brembo RCS.
    Got some Blue Pazzo's for a Blade same as these below for sale if ya interested for £90 delivered?
    Ching Chong Chang one's used on the ZX10 Tracker next to the genuine Blue Blade Pazzo's !
  4. exuptoy
    Colour wouldn't suit my blade but cheers anyway.
    Thanks for the advice so far, keep em coming.
  5. carter
    carter New Member
    Use em on my track bikes... £16 and no drama if I bin it. As for all the horror stories of them snapping on impact.... bollocks. Tried and tested lol. Gonna get a set for my road bike myself, days of spending £120 are over!
  6. TheRamJam
    TheRamJam Well-Known Member
    Sam here, used cheap chinazzo's on the gsxr and now the blade. Hard to see the difference IMO.
  7. binned_it
    binned_it Active Member
    I had some on my blade.
    Looked nice, but snapped off at the base in a very low speed spill, vs the standard levers that bend a bit or snap neatly if you drill them first.
    Also bought some for my dirt bike, which were also weak and broke easily in the wrong place.
    Put me off all Chinese kit: metal really is low grade stuff.
    But as some have said: cheap, and as long as you carry spares, then they are good for track days or budget racing.
    If you dont carry spares then you risk the inconvenience of a snapped lever vs a bent but still ridable lever.
  8. binned_it
    Just remembered that I also had folding cheap Chinese levers for my R1 too, that were supposed to fold instead of breaking.
    They snapped at the base too! Both sides, different spills.
    I guess I'm a slow learner.
  9. exuptoy
    The way I ride if it goes down the levers are gonna be the least of my worries :D
    So long as they are safe to use that's all I need to know.
  10. Dave
    Dave Member
    You don't half crash a lot binned_it:D:D:D
  11. JimGreen
    JimGreen Active Member
    I've had Chinese levers on all three of my last bikes, no problems at all and hard to tell the difference from the real thing.
  12. GappySmeg
    GappySmeg Well-Known Member
    I did have a set of chinese levers on my blade, and although visually identical to Pazzos, the machining tolerances weren't quite correct, resulting in the clutch slipping.
    In fairness, the Ebay supplier refunded my money no questions asked, and didn't insist on me posting the levers back to china.
  13. 1000rrboyjay
    1000rrboyjay Active Member
    I have some nice PP tuning ones, feel pretty good. Look nice, but they'll be off soon as I have Brembo master cylinder on its way. They'll be looking for a new home if you're interested..
  14. exuptoy
    Just got a set from China for £17!! Cheers anyway. If they're shit I'll drop you a line.
  15. 1000rrboyjay
    No worries! Hope they turn out ok!
