throttle position on PC5
Discussion in 'Mods, Upgrades, Accessories and Products' started by pants, Apr 26, 2015.
  1. pants
    pants New Member
    Hi ive got a 2011 blade with a PC5 fitted ive just put on a new map and noticed that the throttle % on the pc5 is flickering between 40 and 100% and the slightest touch on the throttle sends it straight to 100%. Ive tried the reconfigure throttle position on the PC5 but nothing seems to work. Is my TPS knackered or is there anyway of resetting it
  2. charger
    charger Active Member
    Checked the TPS connectors?
  3. pants
    pants New Member
    yeah all seems connected correctly
  4. charger
    You sure you did the calibration in PC5 software right? Just hit reset and then blip to WOT?
  5. pants
    pants New Member
  6. pants
    pants New Member
    Just done an ecu reset then reconnected the PC5 and done a Throttle calibration and it all seems good now thanks for the help charger
