Hi, Just started 2014 blade up instrument panel and head lights don't work everything else ok side lights, brake lights, indicators horn all OK it's under warranty so no problem but any idea what it could be?
I think the headlight and dash use the same loom so I'd check the connection to the main loom and make sure it full pushed together?
starter switch may be stuck half way down, give it a give wiggle and maybe spray with some contact cleaner
I had the same thing with no dash display or headlight. Looked through wiring diagram and found out the headlight is fed from the dash. I disconnected the battery, re-connected and it's all working OK again. Haven't had the problem since fingers crossed.
6 weeks out of warranty and had same thing. Thanks to this forum tried disconnecting the power for a few minutes. All is now well, fingers and toes crossed!!
I think it may have something to do with starting the bike while still having battery charger connected causing voltage spike, that's what I reckon happened to mine.
Mine has done this twice now . Around 11 months apart. Both times disconnected battery resolved problem. Always carry screwdriver now. First time it happened was at work and not connected to charger. Sent from my SM-N910F using Tapatalk
Thanks so much for that info.I had the same problem and sawv your solution so tried it and it worked a treat,but can any one explain why? I would like to know but very grateful all ok now.This forum is awsome,thanks lads.Mines a 2015 in HRC colours and i love it.
Overcharging or voltage spike I reckon as mine did it when I started it with charger still switched on.
thanks for that ritchierich I do use an optimate occasionally but not in this case.Last time was weeks ago and i have never tried to start with charger connected
