Does anyone know if the fuel pump has serviable items such as filter/tea bag? I was told it doesn't but that seems very unusual for a modern bike.
No it isn't bilt hamber is..........http://www.bilthamber.com/fuel-tank-cleaning-kit This combination of products works brilliant at removing rust and cleaning old metal fuel tanks/Jerry can. We used it on Col's blackbird which the bike had been sitting for years and as a result the inside of the tank was corroded stupid and sediment kept blocking the carbs, after using the above combination of products the tank came up like new inside!
CK, most newer vehicles don't have any serviceable parts in the fuel pump (we live in throw away times!), they do still have a tea bag screen type filter to stop the pump picking up large particles but it is normally glued/fixed in place and cannot easily be removed, it can be cleaned tho but the pump still has to be removed in order to achieve that.
I was into this last week, on my 08 I took the pump out and there is a base attached with 4 snap together clips, when this is taken apart then the tea bag filter can be seen, I spoke with Honda about replacing it and he told me it is a non-serviceable part and that a new pump is £360 + He also added that in his long experience he had never known one that needed changing on a blade. Before finding out that piece of info I did find this on eBay, so I think maybe it can be done. http://www.ebay.co.uk/itm/SUZUKI-MO...394?pt=LH_DefaultDomain_3&hash=item27e2a417f2
