isle of man and suspension setup
Discussion in 'General 1000RR Discussion' started by gixerlc, Jun 4, 2015.
  1. gixerlc
    gixerlc Active Member
    Hi everyone hope you are all well, just on the island at the moment on my 2011 got the later shock fitted but still earlier forks,
    Been having a hard time of it getting the bike set up quite alot of banging of the front end bout 12.5stone
    Know its personal but what way has everyone gone set up wise
    I had
    Front forks
    1.75 out rebound from hard
    2.5 compression from hard
    Preload 9.5 turns from full softt
    Rear shock
    1.1 out rebound from hard
    Comp 1.5 out from hard
    Preload notch 5 from soft
    Very sharp handling but horrendous on bumps
    Cant double check sags as girl I'm with couldn't hold the bike
    Now at
    Rebound 1.75 out
    Comp 3 out
    Preload 6 from soft
    Rear
    Preload 4 (standard)
    Rebound about 2 out
    Comp 3.5 out
    Handling isn't as sharp any more still a bit bangy and not settling
    What would you guys all try direction wise
  2. sps170373
    I'd probably go back to standard settings while on the island and having problems as standard settings are designed for your weight!
  3. exuptoy
    exuptoy Elite Member
    I'm near 15 stone plus leathers and my settings for the road ended up being just about the same as standard settings (within a quarter turn) apart from the preload with is in the 8-10 turns front and 6 notches rear IIRC. You'll need more preload if you're 2 up.
  4. exuptoy
    Standard is
    Forks
    6 turns preload from minimum
    rebound (top of the fork) 2-1/4 turns out from full hard,
    comp (bottom) 2 turns out from full hard
    Shock
    preload collar 4th notch
    rebound (bottom of shock) 2-1/4 from full hard
    comp (top adjuster) 2 out from full hard.
    These are for the 08-11 bike tho so cannot help with setting for the standard 12 m.y. shock.
  5. gixerlc
    Cheers everyone, didn't realise standard was for my weight haha
    If anyone has then standard settings for the 12 shock massivly apreciate it,
    Know kais were struggling to get the rebound setup correctly as they said there was barely any adjustment on them and same for the shock, guess everything is exagerrated as bobbing on at a rate of knotts lol + I keep going down all the roads near foxdale horrendous condition don't look bumpy till you pull up and look at them haha, been messing on the billown alot to loads of fun, but back bit near bombhole I rough as haha noticed the back shock seems quite slow when you do the seat push just feels really unballanced so be interesting to try stock
    Tom
  6. exuptoy
    You seem to have way too much rebound and not enough compression. It's gonna be a mixed bag!
  7. Kentblade
    Mate
    Standard 12 onwards rear shock is
    Rear Compression 2 Turns back from Full Clock (Hard)
    Rear Rebound 2.5 Turns back from Full Clock (Hard)
    Rear Preload 4/10
    I run this and it takes most of what's thrown at it on the road, but there maybe be a number of variances on a 14 plate bike it will have no relevance
    Rear Compression 3 Turns back from Full Clock (Hard)
    Rear Rebound 2 Turns back from Full Clock (Hard)
    Rear Preload 6/10
    Same weight as you
  8. gixerlc
    Cheers everyone first settings were done by a suspension specialist was really surprised when I dialed it out,
    Going to dial in stock in a bit and see how I get on with that fingers crossed it gets a bit of balance back into the bike feels really disjointed
    One thing that has crossed my mind is if the front forks are tweaked from that incident I had, didn't intend on using it for the tt but my rzv 500 blew its engine few days before haha
  9. exuptoy
    I have to be honest, I got some settings from Dave Moss and for a track bike they may have been good BUT mine is a road bike and it's so much more compliant and just does what it's supposed to.
  10. gixerlc
    Got some moss settings myself but were in totaly the other direction miles softer less compression on front bout 5 from soft preload etc running alot of compression is really interesting :) how opinions differ setting bikes up
  11. gixerlc
    Just had a wee ride up through foxdale and glen Helen on standard settings, miles better more predictible, front still feels like its firm and a,bit bangy/ skippy on the front
    Thinking maybe take quarter of a turn out on the front and the rear compression? Rebound is reacting faster now and more controlled when I push down
    Has anyone had any squeaking of the big piston rear shock
    Cheers,
    Tom
