Got my laptop with me in work just to edit this! may not be able to upload it tho till I'm home in a fortnight.
Seat re-covered, and gel added. Only did a few miles on it, but it feels good. Rear seat cowl is on the way, so the colour mis match will not be an issue.
Bought a cheap anniversary nose cone and done a Repsol conversion. Also got a cheap sp lower fairing which has also had the same Repsol treatment. Three more panels and i'll be ready for the 2012-2015 conversion
Warning to people!! Make sure your fuel overflow is not blocked or kinked. Think I got away with it just being surface rust, but I've covered the area with ACF50 to be sure. This is what came out after I lifted the tank!!
This Bad Boy arrived last night Fuel Injection Module + Quick Shifter So spent the night fitting that. Also removed the Rear Pegs (My god that is an involved job!!!) Had a Play on it this morning and the Quickshifter needs a little fine tuning but it is Fooking awesome, makes the bike so much better!!
My seat cowl arrived from China this morning, I was very impressed, and unless it falls apart in the next week, £24 well spent.
Fitted the old oem end can back on just for a week, could feel the difference when I took out for a ride, then washed the bike ready for a busy week!
fitted the new Honda clutch plates after fitting my Sigma Slipper clutch. Fitted the Sigma with my old clutch plates last week and all she did when accelerating was SLIP! New plates in, gasket sealer done and went for a spin.. wow, should have done this mod years ago, so smooth changing down gear now and very little engine braking.. very impressed! need one on my track bike now
I ve bought a set beringer calipers ( again lol ) from a friend, but finally hesitate, should i keep my all black Beringer kit or should remplace the front with this new beauty to match my new paint .... hum .....
Personally I'd keep the black one's and sell the others,then use the cash to change the exhaust, just my opinion☺
It's too BIGGG!!!!!!!! IMHO it spoils the lines of the bike,but that's just me, as long as you like it that's all that counts.
