Interesting read on running new bike in from this weeks Mcn
Discussion in 'General 1000RR Discussion' started by Stevie_d, Aug 2, 2015.
  1. Stevie_d
    Stevie_d Senior Member
  2. blakely.wells
    blakely.wells Member
    I've been thinking about this a bit what since buying a new blade. I think always let it warm up. And not to labour it too much. I'm not going to go exploring the rev limiter for a good while I don't think. That said I think I'm going to using most of the rev range after a couple of hundred miles.
  3. foenix
    foenix Active Member
    It's not the rpm who makes the correct run in, but the throttle apply......
    For the first 500 miles, you can't stay over 10 000 but you you can go with brief roll on, and the more important it's to apply SHORT but STRONG throttle ( quick and strong just few second, like 5000 / 8000 ) and never below 4000 rpm, too low in the rpm.
    It's with strong and short throttle an engine run in the best :)
  4. RRoss
    RRoss Active Member
    Pretty much the way i ran mine in and i've not had to top up oil between changes:)
  5. FreddyFred
    FreddyFred New Member
    That's the same as I've always done and never had issues
  6. Stevie_d
    Gave mine 600 miles then rode it fairly hard , not red lining it tho
  7. Kentblade
    Vindication :)
  8. rb1000rr
    rb1000rr Active Member
    Pretty much what i did with mine too now on 36000 and have never needed to top up oil between changes
