2012 end can fitment
Discussion in 'Mods, Upgrades, Accessories and Products' started by raphael, Oct 4, 2015.
  1. raphael
    i have a yoshi r-77 on a 2012 model but I'm not sure what/if any other model it will fit? With one company it says 08-11 and another it says 08-13 does anyone know for sure?
  2. blade1980
    blade1980 Active Member
    I think the actual exhaust is the same, just the cover for the pipe work is different, different panel on '12 onwards for sure
  3. raphael
    Nice one mate,
  4. exuptoy
    exuptoy Elite Member
    Correct, I purchased a used can from a 12 and just had to find a fairing infill from an 08-11
  5. Cook
    Cook Active Member
    Did you have any problems fitting it? I've bought one from a 2012 to put on my 2010 but I've tried ordering the heat shield from cal-sports and he said the cans were different?
  6. exuptoy
    Thats not so mate. I have the 2012 fairing trim supplied with mine then bought a 2008 one from Slick on here. The is a difference in the brackets though but they should be with the trim plate.
  7. Cook
    Cook Active Member
    So if I buy a 08-11 heat shield it'll bolt straight on with the fittings that come with it?
  8. exuptoy
    Thats the theory. Mine did anyway. Personally I'd order one and if it's wrong then send it back. Cal sports are pretty good as are Performance Parts who are the UK importer for all things Yoshi (even supply Calsports I think).
  9. Cook
    Cook Active Member
    Ye I will do cheers bud
