First MOT
Discussion in 'Maintenance' started by RRoss, Jan 28, 2016.
  1. RRoss
    RRoss Active Member
    Bikes gonna be 3 years old shortly and due its first MOT. I've got the baffle for the exhaust at hand and the sticky on reflector for the rear number plate,but am wondering about the chain guard. Does anyone know if it's a requirement that one is fitted for the MOT?
  2. mikesouthby
    mikesouthby Active Member
    No I don't believe so. Certainly I had no problems last year but they were particular about the baffle and reflector!
  3. Greco
    Greco Active Member
    Regarding the chain guard, I wouldnt think so Ross.The sticky on reflectors? Not a requirement either so you'll be ok. Honda dealer last year didnt mentioned anything. The baffle though is an issue - do not forget! Good luck
  4. rebel
    rebel Active Member
    You will need a reflector
  5. SimonRR
    SimonRR God Like
  6. pete954
    pete954 Active Member
    It all depends where you go. A reflector is a requirement. I have had several bikes fitted with baffle free Racefit Exhausts and have no problems getting the MOT.
  7. Jandy
    Jandy Active Member
    I've only had my latest blade 7 months so how come when I picked it up there was no little round reflector on the plate ?????
  8. pete954
    On the OEM plate hanger there is a reflector, I'm guessing you have an after market tail tidy.
  9. RRoss
    RRoss Active Member
    Cheers guys. The test centre I've always used on previous bikes have been fine about exhausts but i'll stick the baffle in anyway as it's a 1 min job. The sticky reflector I've got came from them as they put it on a previous bike that had a tail tidy fitted so it didn't fail. I just take it off and put the plastic film back on the sticky pad after MOT,i've had it about 6 years now. Us Scots are tight you know:D
    It was the chain guard I was concerned about but not any more:)
  10. rebel
    rebel Active Member
    On the reflector if the tester is having a bad day he can fail you for having it on the corner of the plate it has to be central
  11. bonjo
    from the info simon posted rear reflector is only necessary if the bike has no positioning light i.e. tail light which your does
  12. rebel
    rebel Active Member
    Sorry you definitely need a reflector
