Buying advice
Discussion in 'General 1000RR Discussion' started by sean2kuk, Mar 26, 2016.
  1. sean2kuk
    sean2kuk New Member
    Evening everyone
    Having recently sold my bike im after a fireblade, I have a budget of £6500
    after a 2008 onwards model.......from the digging online all ive managed to find is threads UK and USA suggesting 08 and 09 had possible crankshaft issues.....so i looked at a 2010 then read the abs can be abit of a pain.....
    also threads on how amazing these bikes are in comparison to its rivals
    can anyone clear this up for me on what they suggest is the right way for me to go.....what to look out for...what to avoid ect
    thank you
  2. Shutty
    Shutty Well-Known Member
    Most will say avoid abs, to a point some actually remove the system
    2008 can burn a bit of oil, some do, some don't, know real pattern, mine uses 1/2 litre per 1500 miles so no big issue
    Crankshaft can fail upto 10 plate, again rare
    If you can afford, it's a 10 plate, but below this is no big concern
  3. dave d
    dave d Elite Member
    2 Recalls on 08 models coolant pipe and clutch give the reg to any Honda dealer to check to see if they have been done. Good that you know about the ABS issues so you can make an informed choice.
  4. ShinySideUp
    ShinySideUp Elite Member
    Crank issue was not actually resolved until 2011 bikes! So crank whine issue can affect 08, 09 and 2010 engines!
    Honda did alter the 2010 crank by making it heavier than the 08 & 09 bikes but the whine issue which was to do with the case hardening Honda was doing on the crank was not addiquite or done correctly allowing the crank to distort and deteriorate starting with the whine sound then eventually destroying the crank gear teeth!
  5. tony lomas
    tony lomas Member
    Hi Sean I've a 10 plate blade had from new now 8000 miles on her can't fault the bike had no problems and never had to top up the oil .have a scout around the dealers see there stock etc you might get a bargain and you get warranty happy shopping
  6. 1000rr73
    1000rr73 Active Member
    Shame, just traded my 12 plate for not much more money than your budget. I've had 3 08+ blades, and in my opinion stretch to the 12 if you can (although they are all very good) just keep some cash back for the inevitable shiny bits.
  7. Kentblade
    You will not have to stretch that budget much further to get a 2012, step on from the 08-11.
    Think long and hard about your brake choice!!!!
  8. nick2bates
    nick2bates Member
    I got a 2011 with under 12k and only two owners from honda main dealer for just over £6k. Only had it a few weeks and love it. There are some bargains out there. I got the black one, but there was a lovely black and white one for not much more. Same stats.
    Hope you get one soon, experience not to be missed.....
  9. Blackgreg
    Blackgreg New Member
    I did get 2012 for £4k:), but it was cat D, with minimal damage but I mean minimal it cost me around £500 to put it back, using original second hand parts in matching colours and my labourer. It has on 5000miles on the clock.
  10. sean2kuk
    sean2kuk New Member
    so should i favour a 2010 onwards rather than a 08 or 09?
    because of the issues people have experienced....
  11. 1000rr73
    Wow, bargain! Nice find
  12. ColinBR
    You should be able to get a 2011 for that sort of money. By then the crank issue was resolved.
  13. sinewave
    Buy a Kawasaki! :D
  14. graemewalker
    graemewalker Elite Member
    Or a r1m
  15. Singh1000RR
    Singh1000RR Active Member
    I've got a 09 plate. Bullet proof. Not experienced any issues. Check oil monthly - never had to top up. I get it serviced annually - goes like a bullet train.
    New model coming out next year so 08-12 models are going to drop in price. May be worth holding out for an 2012 plate.
  16. red5
    red5 Well-Known Member
    A decent 12 plate is gonna cost 7.5-8k I am looking to buy a new Ducati shortly, I would sell my 15 plate non Abs HRC for 9k 1500 miles Reg Aug 2015
  17. graemewalker
    Cheap that any pics might be interested
