Exhaust springs removal / relatching
Discussion in 'Maintenance' started by lexathon, Mar 28, 2016.
  1. lexathon
    lexathon Active Member
    Apologies if someone else has come up with this before, but I just discovered a super easy way to remove and attach these (having had a pig of a time last time I did it).
    Using a cable tie and an old coathanger (for the hidden one), you can slide the cable tie onto the spring, delicately feed through the coathanger and use it the pull the spring off (and reattach later).
    Made the whole thing super simple and easy.
    Hoping the genius move will make up for not tightening the baffle screw enough, losing the baffle at cadwell park and needing to remove the exhaust to get the screw out!
  2. graemewalker
    graemewalker Elite Member
    Good idea but snipe nose pliers for me don't like the thought of cable tie snapping and bark off hands ooch
  3. sp1n99
    sp1n99 Active Member
    You can get a string puller for a couple of quid:p:p
  4. TrackDayT5
    TrackDayT5 New Member
    pliers and a strong grip,, oh and gritted teeth.
  5. sp1n99
    Makes an easy job difficult.
  6. TrackDayT5
    i found it easy just grip the spring before the hook ?
  7. TrackDayT5
    Demon tweeks
  8. lexathon
    £7.99?
    I can still just about buy a pint for that down in this neck of the woods!
  9. TrackDayT5
    I only need two pints so it's a good deal haha
  10. sp1n99
    £3.49 inc free postage on the bay.
  11. cbr1
    cbr1 Active Member
    i use a tent peg bend the other end put some tape on it so it doesn't dig in to your fingers when you pull . cost / PENCE
  12. lexathon
    Stop it. I spend enough money on eBay as it is!
  13. TrackDayT5
    Looked on outdoor world website couldn't find any gay tent pegs can you mail me one ?
  14. jjones
    jjones New Member
    Bought a similar one of these from eBay and the hook snapped off first useage.
  15. Duncan75
    Duncan75 Active Member
    See if any of the neighbours have a kids trampoline as ours came with a spring puller to set it up, might have one lying around.
  16. TrackDayT5
    Done mine today with a pair of clamp pliers :D doddle !
  17. Fudster
    Fudster Active Member
    I use an old wire coat hanger bent to the required shape and the other end wrapped around a short length of doweling to make a 'T' handle, had it for donkeys years now without any snaps - breakages etc ..... and cost naff all
