LED Headlight
Discussion in 'Mods, Upgrades, Accessories and Products' started by jack930, Apr 19, 2016.
  1. Stevie_d
    Stevie_d Senior Member
    White vision bulbs turned out to be pants , too yellowy my best so far are the diamond vision 5k
    @RRoss
  2. RRoss
    RRoss Active Member
    Cheers,I'll delete them off my wish list and get the diamond vision.
  3. Sean M
    Sean M New Member
    Is there much difference with these???
  4. Stevie_d
    The diamond vision is a hell of a lot whiter, with a slight blue tint. Only slight I must add. Not like these boy racers driving around with blue headlights . The white vision was whiter than standard, with no hint of blue at all . But a bit yellowy , which wasn't what I wanted. Put the diamond vision back in the bike and left the bulbs at my mates garage. Never took any pics.
    Wasted £60 now on 3 sets of h7 bulbs at £20 each, sticking wit diamond vision, match the led lights on my mirrors quite well.
    @RRoss @Sean M
  5. Suttz83
    Suttz83 Active Member
    @Mickydove can you put a link of the ones that you have in those pictures? Defo want some of those.
  6. sps170373
    and that's while having a coffee and a kitkat
  7. sps170373
    Look for my link in the first page same led bulbs
  8. Sean M
    Sean M New Member
    Is the rr7 H7 size bulbs ?
  9. Mickydove
    Mickydove Active Member
  10. Suttz83
  11. Twisted2014
    Twisted2014 Active Member
    After seeing this thread I ordered a set of those LED lights from eBay. Same seller as in the link. I expected them to turn up in about 6 weeks time but they were with me in a couple of days! Decent.
    Fitting is as easy as fitting a new bulb....well...other than it being a little tight. I didn't think it would all fit in but it does.
    If they last I'll buy another set for my car I think.
    Also I only fitted one. Main beam still has the old bulb in. Will use the second LED as a spare.
  12. jack930
    jack930 Active Member
    looks good ,,ill have to order some
  13. Twisted2014
    First night ride last night with the new lights. They are really really good. Significantly better than anything else that I've tried.
    Definitely a recommended Mod.
  14. jack930
    Did they throw out more light and a longer distance ?
    And was you getting cars flashing u due to glare ?
  15. Twisted2014
    More light, further, brighter, better...
    No cars flashing me. THEY WOULDNT DARE!
  16. raphael
    i have just had an mot with them fitted ans sailed through, he even said the lights were spot on!
  17. jack930
    Happy days..on that ill get some orderd..
  18. Twisted2014
    You won't be disappointed. These are the lights I've wanted for some time now. Zero yellow tinge. They are just like lights on 'modern' cars and bikes.
  19. jack930
    Did the small ballast fit ok in the light housing was there plenty of room ?
  20. Twisted2014
    Not gonna lie, it's tight. But managed to get everything inside. You just have to have a little play to get the metal heat sinks and the little transformer all in. I'll take a pic when I get a chance.
