White vision bulbs turned out to be pants , too yellowy my best so far are the diamond vision 5k @RRoss
The diamond vision is a hell of a lot whiter, with a slight blue tint. Only slight I must add. Not like these boy racers driving around with blue headlights . The white vision was whiter than standard, with no hint of blue at all . But a bit yellowy , which wasn't what I wanted. Put the diamond vision back in the bike and left the bulbs at my mates garage. Never took any pics. Wasted £60 now on 3 sets of h7 bulbs at £20 each, sticking wit diamond vision, match the led lights on my mirrors quite well. @RRoss @Sean M
Thanks. I'll get some on order. As said above, what fitment will I need? Mines a 2010 blade. Probably the same fit as yours.
After seeing this thread I ordered a set of those LED lights from eBay. Same seller as in the link. I expected them to turn up in about 6 weeks time but they were with me in a couple of days! Decent. Fitting is as easy as fitting a new bulb....well...other than it being a little tight. I didn't think it would all fit in but it does. If they last I'll buy another set for my car I think. Also I only fitted one. Main beam still has the old bulb in. Will use the second LED as a spare. Sent from my iPhone using Tapatalk
First night ride last night with the new lights. They are really really good. Significantly better than anything else that I've tried. Definitely a recommended Mod. Sent from my iPhone using Tapatalk
Did they throw out more light and a longer distance ? And was you getting cars flashing u due to glare ?
More light, further, brighter, better... No cars flashing me. THEY WOULDNT DARE! Sent from my iPhone using Tapatalk
You won't be disappointed. These are the lights I've wanted for some time now. Zero yellow tinge. They are just like lights on 'modern' cars and bikes.
Not gonna lie, it's tight. But managed to get everything inside. You just have to have a little play to get the metal heat sinks and the little transformer all in. I'll take a pic when I get a chance.
