Ticking engine?
Discussion in 'General 1000RR Discussion' started by Biggeeman, May 15, 2016.
  1. Biggeeman
    Biggeeman New Member
    Tickity engine round about 3/4K rpm
    Seems fine on idle and above 4 k
    Is this a normal valve type noise I can hear
    Or something I should be conserned about.
    Bike is 2005 with 26k drives great not long took ownership so like to iron out potential issues.
    Does have a few mods which may have an impact..
    Yoshimaru end can, downpipes look standard
    Power commander
    K&n air filters
    Was thinking of changing oil to see if that help?
    Cheers for any help in advance
  2. sps170373
    Possibly cam chain tensioner
  3. ColinBR
    Camchain tensioner most likely. I've just changed mine on both my road bike and track bike
  4. Biggeeman
    Ok cool which cct do You buy a new stock one?
    Or aftermarket manual one.
    Can the one I have be serviced or set?
    Thanks
    #4 Biggeeman, May 15, 2016
  5. SimonRR
    SimonRR God Like
    I put an APE manual one on mine :D
  6. ColinBR
    I've put a stock OEM on my road bike and an APE 1 on the. Track bike
  7. Biggeeman
    Which one was easier lol
    I've read it's a bit of a pig of a job.
    Is it ok to ride the bike the now with the tick?
    Got a track day coming up don't fancy pulling the bike apart before that lol.
  8. ColinBR
    The manual 1 takes a bit to set up properly. The OEM 1 takes about 10 minutes to pop in once you get the tank up.
  9. ColinBR
    I wouldn't take it on track of it is ticking away mate
  10. Biggeeman
    Ok mate ta OEM for me then
    Am guessing the stock cct can't be re-set etc
    sure had a zx6r auto cct that was able to be reset.
  11. ColinBR
    No the OEM can't be reset. Basically what happens is the spring loses a bit of its tension in the CCT and then doesn't work properly
  12. Biggeeman
    Ok mate thanks for help!
    Just another if installing an auto OEM one
    Does the engine have to be tdc or can I just swap it out?
