  1. Shutty
    Shutty Well-Known Member
    Eazi grip Evo fitted, never had anything like it on before and quite like it, might be my imagination but feels to ease the upper arm pressures
  2. 1000rrboyjay
    1000rrboyjay Active Member
    Looks good mate
  3. 1000rrboyjay
    I need that heatshield on mine. Got a shitty Austin one that doesn't fit perfectly. Only trouble is waiting the 50 years for it to be painted
  4. sps170373
    Took bike for MOT sailed through
  5. johnd
    johnd Active Member
    Fitted stomp grips.
  6. 1premix
    1premix Active Member
    Went for my last run out before the TT ended up at Devils Bridge and met a certain John McGuiness, nice guy and chatty. Came back patted the tank and started prepping the Blade for the Isle of Man.
  7. Torch'd
    Torch'd Active Member
    Finished the Front end brake swap, half way through the rear now.. Now sat here browsing through the RR site wondering if Blade owners refitted their 'anti squeal shim plate" that clips to the pad!! Found a topic online that said refitting was not necessary and guy who posted thread said his brakes were much much better......? Hmmmmm..
  8. Barstewardsquad
  9. Simon_HRC
    Simon_HRC Active Member
    Put my track fairings on for Silverstone :cool:
  10. Wozza
    Wozza Elite Member
    Fitted new S21 on. Then rode like my 1 st time on a bike hate new tyres , then it starting raining , I started to wet my pants , I know it's all about getting heat in them but I do hate it , 90 miles on them but chicken strips wow , I think it's because I fly to Saudi sat for a new job and didn't want to fall off will go out tomorrow warm them up and over they go......​
  11. RazorBlade
    RazorBlade Member
    The blade is all tucked up in the shed while I'm away on holidays. Needed a "bike fix" so rented a Harley and cruised around the island. The whole no helmet thing took some getting used to but as they say "when in Rome"
  12. Mr OCD
    Mr OCD Well-Known Member
    Few bits and pieces yesterday ...
    - more titanium
    - fitted HRC rear res. (Is it too long?)
    - spot of cleaning
    - serviced rear caliper and installed Brembo pads
    Still scrubs up well :)
  13. 1000rrboyjay
    Sweet. Where are you staying bud?
  14. 1000rrboyjay
    Mate I love it!!
  15. si1000repsol
    Modified the rear master cylinder for the HRC reservoir. It's a cosmetic change but neater. I also have TKR ten Kate rear brake Spring kit fitted
    #6355 si1000repsol, May 22, 2016
  16. MPJ
    MPJ Active Member
    Yes, looks good Mr OCD.
    How are you finding the Rosso III ?
  17. Mr OCD
    Excellent, but they drop in VERY quickly ... Takes some getting use too ...
  18. 1premix
    Port Erin, get there early Thursday practice week.
  19. 1000rrboyjay
    Cool. I'll be at Ballagarey (Glenlough campsite)
    I'll keep an eye out for your bike!
  20. 1premix
    Great place to watch from.
